Brake lights not Working - JeepForum.com
post #1 of 7 Old 08-25-2011, 08:32 PM Thread Starter
clnlibrty
i have a 07 KJ thats having a brake light problem. ive checked all my fuses and there all good. my parking lights are working, blinkers are working. brake light are just not working when i push on the brake. does anyone have any suggestions or anything
sorry if this is a repost, but i couldnt find any post on this
clnlibrty is offline
post #2 of 7 Old 08-25-2011, 09:23 PM
95BadBoy
Check the ground on your brake lights would be a good first step. Volt meter will help if you have access to one.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #3 of 7 Old 08-25-2011, 09:43 PM
tjkj2002
2002 KJ Liberty
Check the brake light switch that is on the brake pedal.
tjkj2002 is offline
post #4 of 7 Old 08-26-2011, 08:02 PM Thread Starter
clnlibrty
ok so i replaced the brake light switch and nothing. the orignal light switch was still good but i switched it out ether way. so im completely lost on this one, cant even drive around because i really dont feel like getting a ticket for no brake lights.compleat. someone has to know something
post #5 of 7 Old 08-27-2011, 02:01 AM
Billwill
2002 KJ Liberty
As 95Badboy said...you need to get hold of a voltmeter.
Turn on the ignition and jam the brake pedal down with a lenght of timber then measure at the brake light for voltage.
First measure between the connection on the bulb itself and the ground on the bulb itself....if you have 12 volts there then your bulbs are blown or you have dirty contacts inside the bulb holder.
Now measure between the connection on the bulb and the other meter lead going to the chassis somewhere....if you now have voltage it means the grounding to the bulb holders is gone which is a common problem.
If you do not have voltage at the rear at all then you need to start measuring the voltage at the brake switch.
Does the third brake light work? If not then you probably are losing voltage right up front near the brake switch.
Once you have a multimeter to fault find....even a cheap one....the rest is not rocket science!
Billwill is offline
post #6 of 7 Old 08-29-2011, 11:51 PM
roertw006
2004 KJ Liberty
this is strange... i was actually going to post a new thread about this same thing. mine is an '04... i guess theyre just starting to get to be old cars.
symptoms: no brake lights (1 or 2), 3rd brake light works. tail lights/parking lights work fine. checked brake light bulb on one side and it was ok(i assume both are, and if not, i at least have a problem with the one side). i checked the fuse, and it is ok(which makes sense, otherwise my 3rd brake light wouldnt work). i suspected it may be the switch at the brake pedal, but i cant imagine it could be because, again, the 3rd brake light works.
from what i can tell, im not getting current to my brake light bulb(s). where are the other places/things i should check? anyone experience this kind of thing before(besides clnlibrty)?
Robert W.
'04 Jeep Liberty, some 2-wheelers, and some British things
roertw006 is offline
post #7 of 7 Old 08-30-2011, 05:12 AM
Billwill
2002 KJ Liberty
Do the steps I mentioned in my post above....the most common problem is that the ground for the rear bulbs gets lost....that is why I say check that you have voltage measuring between the positive contact on the bulb and the ground point on the bulb.....then move the lead from the ground point on the bulb onto a portion of clean chassis ie. a bolt on the rear door hinge.
A lot of people have fixed the missing ground point by drilling a small hole into the bodywork inside the rear cluster holder, scrape off some paint there, fit a new piece of wire to that hole by means of a self-tapping screw, connect this new wire to the ground portion of the brake bulb holder....you can never have too many grounds.
Billwill is offline
One brake light not working when lights on d5332 KJ Liberty Forum 11 12-02-2013 07:46 PM
Dashboard lights not working!!! mtmandersen KJ Liberty Forum 4 10-03-2011 11:16 AM
ABS/brake lights + funny sensation in brake pedal and sound as well zooomzoom KJ Liberty Forum 3 07-21-2011 01:22 PM
Reverse lights not working and truck starts even if clutch not engaged RVD56 KJ Liberty Forum 2 05-31-2011 11:04 PM
trailer turn-signals and brake lights not working with Jeep Ducatista KJ Liberty Forum 3 06-12-2006 07:06 AM
