bought a diesel - need some help code 0504 - JeepForum.com
post #1 of 9 Old 10-18-2010, 03:40 AM Thread Starter
makim
hi Guys
I recently bought my first jeep liberty (diesel)
But I've been having problems with it right from the start. I invested few hundred and it's runnin ok, but now another code showed up
Brake Switch 0504
Anybody know what it means/.is ?
help
makim is offline
post #2 of 9 Old 10-18-2010, 06:18 AM
GDE
2005 KJ Liberty
This is a plausibility check between the primary and secondary brake switches. One of the sensors detecting the brake being pressed is not functioning properly. There is one sensor near the brake pedal used to detect pedal movement and there should be one off the master cylinder detecting braking effort via a pressure switch, one of these might be having issues. Or if you are resting your foot on the brake pedal while driving, it might be possible to set the pedal movement sensor to '1', while the pressure sensor is still detecting '0', the plausibility fault will set if one sensor is detecting '1' and the other detecting '0' for a long enough time period. Good luck.
GDE is offline
post #3 of 9 Old 10-18-2010, 11:37 AM Thread Starter
makim
thank you so much for this info
Is there an online pdf manual, where I can find this part and part number?
makim is offline
post #4 of 9 Old 10-18-2010, 11:51 AM
95BadBoy
First post - welcome to JF -
Looks like you have some info from GDE for tracking down your P 0504 code.
Some other things to think about that are not related but good ideas for your CRD.
Cleaning your MAP sensor.
Checking to see if there is any fuel weep-age or scoring/melting at the fuel heater plug on your fuel head. It is the right hand plug when looking at the fuel head from the front. If it is the original fuel head, I would unplug it. Been known to cause a few serious meltdowns under the hood and air ingress into the fuel system.
Invest in a real tune to IXNAY the EGR (plus many other things). Really don't want that left fully functional.
Good idea to fill out your Jeeps profile so those responding know what you are working with.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #5 of 9 Old 10-18-2010, 04:02 PM
CRD_Joe
2005 KJ Liberty
With respect to this forum, youll have more luck looking here:
LOST JEEPS • View forum - Liberty CRD...Love that Torque!!!
2005 KJ CRD Sport
Suncoast, Transco, Inmotion, Provent, SEGR, CAT2, HID's, Samco hoses, louvers, V6 airbox, Fumoto, 2.5" cat back no muffler
CRD_Joe is offline
post #6 of 9 Old 10-19-2010, 03:35 PM
merlinTec
merlinTec's Avatar
Hi
There is a ECM software flash for this DTC there may not be a fault with your jeeps it's just a software glitch.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #7 of 9 Old 10-19-2010, 04:37 PM
95BadBoy
Originally Posted by merlinTec View Post
Hi
Does this software flash pertain to the 05/06 models only - or was it also encompassing the earlier 2.5's & later models that you have on your side of the pond?
Just curious is all merlin. Inquiring minds you know.
95BadBoy is offline
post #8 of 9 Old 10-20-2010, 01:53 AM Thread Starter
makim
Hi
where can I get this flash, is it dealer only?
makim is offline
post #9 of 9 Old 10-20-2010, 06:57 AM
GDE
2005 KJ Liberty
This was a very early reflash in October of 2005. The engine ECU part number revved from 56044562CC to 56044562CD. Not sure if the reflash would really help your situation or not. The only change to this diagnostic Chrysler made was to make this fault code a 2 trip CEL verses and immediate CEL. Then again it might help, with this change the fault must be present for two complete driving cycles before the CEL is turned on. A driving cycle is a warm-up, drive and shut down over a certain time period. A dealer scan tool can show you what the part number is inside the ECU, do not rely on the stickers affixed to the ECU.
GDE is offline
Jeep Liberty Diesel code P0069 racecarricky KJ Liberty Forum 8 10-06-2010 06:35 PM
Bio Diesel LONEPINERON KJ Liberty Forum 18 07-22-2007 12:46 AM
BP diesel TisforTrue KJ Liberty Forum 4 01-27-2006 08:32 PM
Bio diesel in CRD 4wlrkiller KJ Liberty Forum 24 09-28-2005 08:57 PM
Why Diesel not available in NY?? bkeast17 KJ Liberty Forum 8 06-03-2004 09:53 AM
