Battery Light on Liberty 2002. Help!!! - JeepForum.com
post #1 of 4 Old 02-09-2010, 11:57 AM Thread Starter
LDaz
2002 KJ Liberty
I have a Jeep Liberty 2002 and the Battery Lights comes on and stays on resulting on complete battery drain. Can someone let me know the possible cause. I have replaced the Alternator and new battery.
any help or suggestion would be appreciated.
Thanks.
LDaz is offline
post #2 of 4 Old 02-09-2010, 01:12 PM
tjkj2002
2002 KJ Liberty
The PCM has the voltage regulator in it.Time for a trip to the dealership since the DRBIII(or StarScan) will be needed to properly test the charging system.
tjkj2002 is offline
post #3 of 4 Old 02-09-2010, 03:13 PM
yellocoyote
2002 KJ Liberty
Check for damaged battery wiring also - had that happen to mine not too long ago. Needed to replace battery wiring harness.
yellocoyote is offline
post #4 of 4 Old 02-10-2010, 05:42 AM
Billwill
2002 KJ Liberty
The circuit diagrams are available in section 8 of the Service manual available in the Sticky above.
There is normaly a fusable link within the wiring going from the thick positive wire to the alternator...you need to check that although I am talking from experience with the 2002 2.5 CRD...wire is thick green one I think!
If you know some electronics you can trace the wiring using the circuit diagrams..I had problems with my harness carrying the battery sense voltage to the ECM (PCM in the gas model!)
Billwill is offline
2002 Liberty Air Bag LIght on seanskijeep KJ Liberty Forum 17 10-10-2017 11:04 AM
2002 Liberty - Oil Light, Leaks, etc. muzicman82 KJ Liberty Forum 16 08-07-2010 10:00 PM
2002 CRD Battery Light on Billwill KJ Liberty Forum 1 08-30-2009 04:09 AM
Electrical problems, dome light, radio in 2002 Liberty benny33 KJ Liberty Forum 3 08-12-2009 04:23 PM
Check Engine Light 2002 Liberty grabick_luca KJ Liberty Forum 11 06-16-2009 09:18 PM
