Average MPG... - JeepForum.com
post #1 of 12 Old 05-27-2014, 02:33 PM Thread Starter
02jeepliberty
Average MPG...
I have the OTIS overhead console and I was looking at the Average MPG and accidentally hit the reset button. It immediately went to "0.0" and stayed their till I drove. Then it bounced back up to 12.7 and has slowly been going up...keep in mind before I hit the reset button, it was at 14.1...now it's in the 15.6-7 range and constantly goes up or down depending on what I do. If I accelerate quickly it goes down .1 or .2 then goes back once I'm up at speed. So my question is, is it normal for it to react that way if the reset button is hit? Is it normal for it to go up and down as quickly as it is? And is it accurate? Remember before it was in the 14 range, now it's in the high 15 range...any help will be MUCH appreciated!
Nathan
02jeepliberty is offline
post #2 of 12 Old 05-27-2014, 02:37 PM
brendanc
2002 KJ Liberty
Yes, because your average is now based on much less driving time. At first it behaves much like instant MPG because it doesnt have anything to average against.
02 Liberty, 4" JBA Gold Lift
brendanc is offline
post #3 of 12 Old 05-27-2014, 03:17 PM Thread Starter
02jeepliberty
okay, so how long will in generally take till it stops going up and down so quickly? And then what it is doing is normal then, right?
post #4 of 12 Old 05-27-2014, 03:18 PM Thread Starter
02jeepliberty
it, not in**
post #5 of 12 Old 05-27-2014, 03:22 PM
tjkj2002
2002 KJ Liberty
That reading is the average mpg's for the mileage driven,that mileage re-started at 0 when you hit reset.Expect several hundred miles before drastic changes stop but the more miles the less accurate that reading is(not that it's very accurate to begin with) since it's averaging several hundred/thousand miles instead of a few miles.
Basically if you go 1000 miles and all of a sudden your mpg's drop by say 4-5mpg's it will not effect that reading very much and not warn you of a issue since it will take several hundred miles at a much lower mpg to move that average scale.
tjkj2002 is offline
post #6 of 12 Old 05-27-2014, 03:22 PM
brendanc
2002 KJ Liberty
1) Yes, it is normal behavior.
2) In practice it will change slower the longer you drive it without resetting it (how often/far you drive will affect this--erratic driving will as well). Why does it matter, though? Does it bother you (just curious)?
Edit:
I guess Troy and I posted at nearly the same time. I want to add in addition to his explanation that it's probably good to reset after every tank to get a better feel for your MPG, keeping in mind that it's not extremely accurate to begin with.
brendanc is offline
post #7 of 12 Old 05-27-2014, 03:29 PM
remmons
That little indicator will only give you your TOTAL average MPG, it will not change with every fill up. If you want your average each fill up, use your trip meter and divide that by your gallons pumped. As you will tell it will too fluctuate because of your varied driving experiences, i.e. all in-town, partial in-town and highway, or all highway.
Robert.
remmons is offline
post #8 of 12 Old 05-27-2014, 04:05 PM Thread Starter
02jeepliberty
1) Yes, it is normal behavior. 2) In practice it will change slower the longer you drive it without resetting it (how often/far you drive will affect this--erratic driving will as well). Why does it matter, though? Does it bother you (just curious)? Edit: I guess Troy and I posted at nearly the same time. I want to add in addition to his explanation that it's probably good to reset after every tank to get a better feel for your MPG, keeping in mind that it's not extremely accurate to begin with.
okay, well it just makes me mad that it moves around a lot. I'm mad at myself that I hit that button, I think I have OCD when it comes to this type of stuff lol
post #9 of 12 Old 05-28-2014, 07:19 AM
olliehopnoodle
1982 FSJ Cherokee
Change the display setting to outside temp. Problem solved.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #10 of 12 Old 05-28-2014, 07:25 AM Thread Starter
02jeepliberty
Yes, that always works!
post #11 of 12 Old 05-28-2014, 11:39 AM
DaveJKJ
2005 KJ Liberty
Why be mad? It is only "doing it's thing" and will continue to work as an "instant" readout until it registers more miles and settles down to an "average" mpg readout.
Lifted, Skids, Hooks, Rails, Trail Rash..
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline
post #12 of 12 Old 05-28-2014, 08:16 PM Thread Starter
02jeepliberty
Well, i'm not really mad, just disappointed I hit the reset button on accident. I feel like I have to drive like an angel now for it to go back to where it was but I guess it is good I did reset it so I can have an updated readout. I don't care really anymore, it is what it is.It just worried me at first because I didn't know if it was normal, but it makes sense why it's doing that.
