Automatic Trans downshifting problem - JeepForum.com
post #1 of 7 Old 06-06-2011, 09:42 AM Thread Starter
20Jeep03
2003 KJ Liberty
My Transmission downshifts real hard , second to first is the worse, trans does not slip otherwise is ok, upshifts ok.just when it downshifts its like "BAM"
any ideas ? changed fluid and filter.
20Jeep03 is offline
post #2 of 7 Old 06-06-2011, 11:21 AM
Joenavy85
2005 KJ Liberty
Joenavy85 is offline
post #3 of 7 Old 06-15-2011, 08:41 AM Thread Starter
20Jeep03
2003 KJ Liberty
read that thread
Mine is not like that thread, It downshifts hard going from 3rd to second and second to first , no upshift problems......please help it has no transmission noise or gear noise
20Jeep03 is offline
post #4 of 7 Old 06-15-2011, 05:47 PM
TwoBobsKJ
2003 KJ Liberty
That is a common issue when a transmission is rebuilt, repaired or replaced and sometimes when there is a complete fluid flush and filter replacement. Jeep/Chrysler has a process called "Quick Learn" in which a scanner is connected to the OBDII port and the trans TCM is flashed to eliminate the hard downshifts. The flash can be done by a competent trans shop or a good mechanic who regularly works on transmissions.
Have you had any work done on the transmission? If so it may need a Quick Learn. If you haven't had work done try disconnecting the negative battery cable for 20-30 minutes, reconnect it then drive the Jeep. That may reset things back to normal.
My .02...
Bob
TwoBobsKJ is offline
post #5 of 7 Old 06-16-2011, 06:01 PM Thread Starter
20Jeep03
2003 KJ Liberty
I will Try that....
thanks
20Jeep03 is offline
post #6 of 7 Old 06-16-2011, 07:57 PM
richd
2008 KK Liberty
thanks
You can try this method,its the easiest to do:
METHOD1:
1. Pull BOTH battery cables completely off of the battery !! - disconnect the cables totally from the Battery and bolt the
cables together - not the battery posts!! (or connect the cables together with jumper cables)
2. Turn the ignition key to the ON position
3. Stand on the brakes
4. Remain in this condition from 5-10 minutes to assure complete draining of all the capacitors in the entire electrical system!
5. Turn the ignition key off.
6. Connect everything back up again, reset your clock and stereo presets.
7. Take the car on the road and jump on it!!
8. Drive the car a little harder than usual for a day or two and you should notice the difference from then on.
I use to also take drive in the city and go through the gears when leaving a stop,do this several times,then take it on the highway,start slow speeds,then hit the passing gear a few times.Shut off vehicle then take a drive and see if it resets.
richd is offline
post #7 of 7 Old 12-26-2015, 05:27 AM
libby03
2003 KJ Liberty
METHOD1:
No replies after this. So.... anyone tried this method? I'm having the same problems now.
libby03 is offline
Automatic Transmission Problem JBD KJ Liberty Forum 4 03-19-2012 05:10 PM
KJ trans problem? FXSTCHEWY KJ Liberty Forum 1 02-15-2010 08:24 PM
Towing w Liberty Automatic Trans. paleoman KJ Liberty Forum 7 07-21-2009 02:45 PM
2007 Liberty not downshifting conky KJ Liberty Forum 9 04-02-2009 07:35 PM
Downshifting AT bobcat7 KJ Liberty Forum 17 10-28-2008 01:32 PM
