Argghh...Front end growl not wheel bearing! What is it? - JeepForum.com
post #1 of 5 Old 05-18-2013, 07:21 AM Thread Starter
dac122
2004 Jeep Liberty Sport 3.7L V6 4x4.
I have a front end speed related growl. When turning right it changes pitch. I naturally assumed a left wheel bearing and replaced, but...arggghhh that did not do it!
Four months ago I replaced the front pinion seal and was super duper careful to tighten everything exactly correct. I sure hope the input bearing is not bad.
Any ideas what it could be?
dac122 is offline
post #2 of 5 Old 05-18-2013, 01:30 PM
TheBlueKJ
2003 KJ Liberty
Did you torque everything with the full weight of the vehicle on the ground?
Blue 2003 Jeep Liberty Sport 4x4 Lifted, Front OME 790s/Bilstien, Custom Rear; 245/75/16 A/Ts KC Daylighters
thread)
TheBlueKJ is offline
post #3 of 5 Old 05-18-2013, 06:56 PM
Bain98xj
When turning right does it get louder or quieter?
Bain98xj is offline
post #4 of 5 Old 05-18-2013, 06:58 PM
Bain98xj
I just had my lf wheel bearing go and untill I put it on a hoist and ran it up to about 30mph I always thought it was the right
Bain98xj is offline
post #5 of 5 Old 05-18-2013, 08:38 PM
TwoBobsKJ
2003 KJ Liberty
Here's one out of left field...
Check the CV joint on the transfer case end of the front driveshaft. If the boot is torn or missing the the joint is toast - and will make goofy noises that can be mistaken for other components going bad.
Slide under there and take a peak - you may be surprised.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
