Anyway to disable the tire pressure monitor system or TPM :) - JeepForum.com
post #1 of 12 Old 01-30-2006, 08:20 PM Thread Starter
lbrty13
Subject says it all....... i put some aftermarket wheels on my '05 Libby and now have to deal with the annoying light on my dash and quick beep error code from the EVIC....... not a big deal, but annoying enough.
lbrty13 is offline
post #2 of 12 Old 01-31-2006, 07:37 AM
hyedipin
hyedipin's Avatar
Hi, Couldn't they put them on the new wheels for you? I thought they were removable.
hyedipin is offline
post #3 of 12 Old 01-31-2006, 10:30 AM
Diesel Inferno
I would ask why they didnt put them on the new wheels first. I do think the light can be turned off by the Dealer via the cars CPU.
Downers Grove Illinois
2005 Inferno Red Sport CRD
Diesel Inferno is offline
post #4 of 12 Old 01-31-2006, 10:38 AM
hyedipin
hyedipin's Avatar
and also any pictures you can show us, which kind of wheels you've got
hyedipin is offline
post #5 of 12 Old 01-31-2006, 06:05 PM
VTNomad
Tpms
It could be the new wheels are steel. The sensors don't work with most steel wheels. I think I read somewhere it is illegal to disable TPMS on 2005 and newer vehicles.
2012 Black Jeep Wrangler Rubicon 2-door
VTNomad is offline
post #6 of 12 Old 01-31-2006, 08:46 PM
hyedipin
hyedipin's Avatar
illegal? that's the first time I hear this. Some people lower it to 20's, I'd hate hearing beep beep beep and flashes overhead while crawling..
hyedipin is offline
post #7 of 12 Old 02-01-2006, 05:35 AM
brandoncrone
I don't know if it is that the wheels are steel or not. Starting in 2007 all passenger vehicles are required by law to have some sort of TPM system onboard. So some are going to have steelies and some are not. I don't see DCX using 2 different TPM systems. The TPM sensors should work with steels as the valve stem part that sticks out of the wheel is the antennae.
Dodge/Chrysler/Jeep Technician 14 Years
ASE Master Certified
L1 Advanced Engine Performance
brandoncrone is offline
post #8 of 12 Old 02-01-2006, 06:14 AM
VTNomad
Tpms
http://www.nhtsa.dot.gov/cars/rules/...nalrule.6.html
SUMMARY: This final rule establishes a new Federal motor vehicle safety standard (FMVSS) requiring installation of a tire pressure monitoring system (TPMS) capable of detecting when one or more of a vehicle’s tires is significantly under-inflated. This final rule responds to a mandate in the Transportation Recall Enhancement, Accountability, and Documentation (TREAD) Act. This final rule requires installation in all new light vehicles of a TPMS capable of detecting when one or more of the vehicle’s tires, up to all four tires, is 25 percent or more below the manufacturer’s recommended inflation pressure (placard pressure) or a minimum activation pressure specified in the standard, whichever is higher.
DATES:
Effective Date: This final rule is effective April 8, 2005, except for Subpart G of 49 CFR Part 585, which is effective September 1, 2005.
Compliance Date: Consistent with the phase-in commencing October 5, 2005, all new light vehicles must be equipped with a TPMS that meets the requirements of the standard by September 1, 2007, with the following exceptions. Vehicle manufacturers need not meet the standard’s requirements for the TPMS malfunction indicator and related owner’s manual language until September 1, 2007 (i.e., at the end of the phase-in), and vehicles produced by final-stage manufacturers and alterers must be equipped with a compliant TPMS (including a malfunction indicator) by September 1, 2008. However, manufacturers may voluntarily certify vehicles to FMVSS No. 138 and earn carry-forward credits for compliant vehicles, produced in excess of the phase-in requirements, that are manufactured between April 8, 2005, and the conclusion of the phase-in.
Check your valve stems, if they look like these, then they are the TPMS stems.
VTNomad is offline
post #9 of 12 Old 02-01-2006, 08:05 AM
hyedipin
hyedipin's Avatar
Thanks for the info. It should not be illegal to disable the PSI monitor on EVIC. Jeeps have TPMS on dashboard, EVIC is PSI monitor.
hyedipin is offline
post #10 of 12 Old 02-02-2006, 05:51 AM
brandoncrone
Its not illegal to not have the TPM, you cant turn it off, its part of the wireless control module (or SKREEM module depending on the vehicle) which also controls the transponder in the key and the RKE. Its there to stay, dealers can't disable it and can't reset it. It has to reset on its own when the sensors are in place. The EVIC has nothing to do with the TPM anymore, all it does is display the results.
post #11 of 12 Old 02-02-2006, 07:37 AM
hyedipin
hyedipin's Avatar
Good info brandon.
Thanks.
hyedipin is offline
post #12 of 12 Old 02-04-2006, 12:00 AM
rob92xj
1992 XJ Cherokee
By 2007 or 2010 it will be a standard feature thanks to Ford and there Explorer.
rob92xj is offline
05 Liberty Tire Pressure System RetiredSERE KJ Liberty Forum 8 04-03-2009 09:16 PM
tire pressure management system donkey77 KJ Liberty Forum 5 03-04-2009 05:06 PM
Change Tire, Tire Pressure Monitor Location? Valkraider KJ Liberty Forum 1 01-12-2006 01:35 PM
3" lift with tire pressure monitor? kdiplacido KJ Liberty Forum 8 08-20-2005 08:49 PM
Tire pressure monitoring system ( TPMS ) VTNomad KJ Liberty Forum 6 04-09-2005 09:18 PM
