Anyone mounted Pro Comp series 7031 on 2004 Liberty with no lift kit?? - JeepForum.com
post #1 of 3 Old 06-29-2012, 12:51 PM Thread Starter
jtloud
2006 WK
My son wants to put a set of Pro Comp series 7031 wheels on his 2004 Liberty Limited (4WD). Has anyone out there mounted a set of these without having any problems?? Also, I can't find any reliable source on the internet as to whether or not that model wheel will work on a Liberty.
I'm hesitant to put a lift kit on his because of the independent front suspension. My concern is that lifting it up may interfere with a proper front end alignment.
Thanks.
jtloud is offline
post #2 of 3 Old 06-29-2012, 08:44 PM
oilbuner
2006 KJ Liberty
LIFT IT!! These Jeeps are great with the right lift kit!! Go with JeepinbyAl, Frankinlift or OME. Theses are the only kits with bullet proof results. There is plenty of info on JEEPForum. Good luck. Oilburner
When the pavement ends, you better have some ground clearance!
oilbuner is offline
post #3 of 3 Old 06-29-2012, 08:48 PM
tommudd
2004 KJ Liberty
Not OEM I think he means OME
You can lift up to 3 inches or so real easy 750 or so in parts
ride will be better on and off road
Not sure what wheels you are talking about
lifted you can run 16X7 with 4 inches of backspacing
A "good" alignment person can get into spec, mine been lifted over 150,000 miles and i know of several others just the same
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
05 KJ
tommudd is offline
Pro Comp Series 98 wheels mopartilidie KJ Liberty Forum 17 01-25-2011 10:11 PM
2004 Liberty sgtblanco KJ Liberty Forum 4 01-05-2011 06:03 PM
2004 Liberty got6steelman KJ Liberty Forum 1 10-21-2010 04:29 PM
2004 Liberty ABS 3Wide KJ Liberty Forum 16 03-28-2010 02:19 AM
Will a 2004 liberty bumper fit an 05 to 07 liberty metalhead KJ Liberty Forum 2 09-05-2009 06:39 PM
