anyone knw what this problem is - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > anyone knw what this problem is
Father's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPIRough Country Lift Kits and Parts!
Unread 06-20-2012, 05:18 PM   #1
scjeep69
2002 KJ Liberty
I have an 02 jeep liberty sport 4wd 3.7 v6. When I crank it up it'll start n run and imeaditly shut off almost look not getting fuel... but here's the catch if I. Crankit give it the gas and keep it up to around 1500 to 2000 rpms for a couple mins it'll run fine... any help would be greatly appreciated... o and since this problem mpg sucks...
scjeep69 is offline   Reply With Quote
Unread 06-20-2012, 10:02 PM   #2
PNW05KJ
2005 KJ Liberty
Sea Foam...
PNW05KJ is offline   Reply With Quote
Unread 06-21-2012, 01:08 AM   #3
sens
2002 KJ Liberty
Is seafoam recommended here?
I think the idea of it is great, but I was also under the impression it caused a lot of issues, fouling the spark plugs, fouling the catalytic converter and rest of the pipes, eating away at rubber seals etc.
sens is offline   Reply With Quote
Unread 06-21-2012, 02:38 AM   #4
Vikk
Idle control valve?
Vikk is offline   Reply With Quote
Unread 06-21-2012, 06:25 AM   #5
streetglideok
2005 KJ Liberty
I found seafoam to be all but useless in cleaning anything really dirty. Makes pretty smoke, to make you think it works, but that is just the chemical itself burning. There's some good stuff from BG, Valvoline, Ford, and Mopar that will clean the top end of the engine and make it look like new.
Your symptoms sound like a dirty idle control solenoid/valve, or a faulty one. A good cleaning of the throttlebody would do wonders.
streetglideok is offline   Reply With Quote
Unread 06-21-2012, 11:53 AM   #6
tjkj2002
2002 KJ Liberty
A issue like yours has also been known to be caused by a bad battery.
tjkj2002 is offline   Reply With Quote
Unread 06-21-2012, 03:07 PM   #7
pssbarry
x2 on the battery. I've had the exact issue a couple of times and both times the battery was the fix.
pssbarry is offline   Reply With Quote
Unread 06-21-2012, 06:12 PM   #8
scjeep69
2002 KJ Liberty
Ok well that makes sense bc my terminal was cracked and I just recently fixed that last5 night it ran fine today.... but one more question sometimes when I cut my blinker on my interior lights will flash anyone ever had this issue
Unread 06-21-2012, 06:22 PM   #9
tjkj2002
2002 KJ Liberty
That is a multifuction switch(turn signal/headlight,wipers) going bad.Takes like 5mins to change out.
Unread 06-22-2012, 01:59 PM   #10
scjeep69
2002 KJ Liberty
So change the actual switch that you use to cut your blinkers,windsheild wipers head lights ect.?
Unread 06-22-2012, 08:17 PM   #11
tjkj2002
2002 KJ Liberty
Yep,about $100 from the dealership(last I've checked,could be more now).
Unread 06-23-2012, 12:21 AM   #12
Billwill
2002 KJ Liberty
Make sure you get the correct switch.There are two types of switch depending on if you have front fog lights fitted or not
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline   Reply With Quote
