Any difference between '05/'06 CRD - JeepForum.com
post #1 of 11 Old 02-22-2007, 06:11 PM Thread Starter
dougsmith
2005 KJ Liberty
I'm very interested in buying a Liberty with the CRD.
Is there any difference in reliability between the '06's ad '05's or any other reason the '05 might not be a good value?
dougsmith is offline
post #2 of 11 Old 02-22-2007, 06:51 PM
rob92xj
1992 XJ Cherokee
The 06 CRD's have the newer style EGR valve and flow control valve, thats really the only difference.
rob92xj is offline
post #3 of 11 Old 02-22-2007, 08:10 PM
CATCRD
2005 KJ Liberty
The 06 has ESP and no trak-lok axle.
CATCRD is offline
post #4 of 11 Old 02-23-2007, 06:37 AM
BVCRD
........................and any built after 10/05 don't qualify for, or need the F37 recall. And there is of course the warranty difference.
2006 Jeep Liberty Sport CRD
BVCRD is offline
post #5 of 11 Old 02-23-2007, 03:32 PM
LONEPINERON
I would say the bigest thing is the warranty 3-36k for 06 7-70k for 05
'94 YJ 4" LIFT, 2.5LTR, 5 SP, 4.10, WARN WINCH. 265X16 TIRES AND WHEELS. '06 KJ CRD limited 4wd every option except heated seats and Mirrors.
LONEPINERON is offline
post #6 of 11 Old 02-24-2007, 06:29 AM
RFCRD
The primary difference is with the '06 having ESP (combo package: stability & traction control, and anti-lock brakes) and the '05's have just ABS. DCX also changed the warranty protection between model years.
Neither model year will be a value if the vehicle is full of running defects and/or your dealer is clueless with fixing a CRD. This isn't the type of vehicle you want to buy used/sight-unseen from a seller hundreds or thousands of miles away. There are some cheap buys floating around as many owners are dumping out of these because they can't and their dealers won't fix their issues. Just be carefull what you buy and go into this with the expectation that the vehicle may need more love than normal.
RFCRD is offline
post #7 of 11 Old 02-24-2007, 07:30 AM
BVCRD
You will find that MOST CRD owners are happy with their rig. There will always be a few who aren't no matter what make it is.
BVCRD is offline
post #8 of 11 Old 02-24-2007, 08:40 AM Thread Starter
dougsmith
2005 KJ Liberty
Thanks for all the info.
I found an '05 w/ 36K miles at a dealer. No obvious problems, except that there is an open recall on the torque converter and the mileage computer reads 15 mpg (might have been on the lot for a while; dealer was not clear on history).
Anything to worry about?
post #9 of 11 Old 02-24-2007, 08:50 AM
BVCRD
This is a case where 36,000 miles on an 05 is a good thing. To many miles to be a lemon. You already know about the TC and LBJ recalls. Get the F37 recall done and you should have a nice rig. I wouldn't worry too much about the 15 mpg. Could be a city driver, or who knows. There is a transferable warranty that you will want to take care of. Congrats.
BVCRD is offline
post #10 of 11 Old 02-24-2007, 08:21 PM
RFCRD
If it's not throwing codes and runs OK, you should be fine. The 36K miles was the end of the bumper-to-bumper portion of the warranty. You might want to inspect the minor stuff like the charged air hoses for oil soaking. Get them replaced before delivery if they are soft or sweating oil as they are pricey (pull the woven guard back where it connects to the turbo and look for an oily coating). You should also know that the EGR valve is not covered under the 7/70 powertrain warranty so get it replaced now if it's giving any problems. Good luck.
RFCRD is offline
post #11 of 11 Old 02-25-2007, 09:30 AM
xyz123
Super Senior Member
If its right at 36k you might be able to purchase an extended warranty..or get them to throw one in on the deal..in my case, I knew I would put alot of miles on mine in a short period.. I just rolled over 36k in just under 1.5 years..Initially, I purchased a 5 year, 100k bumper to bumper warranty..small price to pay for a piece of mind..
and this past Thursday, running 75 to 80 mph on a 200 mile interstate trip, I got 29.2 mpg...the jeep on the lot has also probably been idling a lot (everybody wants to "hear" the diesel Liberty) which will pull the mileage on the evic down quickly..
xyz123 is offline
What is the difference - KK v KJ???? Redrider39 KJ Liberty Forum 50 06-21-2015 01:53 PM
Much difference between Wrangler ST and SR-A?? Monstermile KJ Liberty Forum 14 01-11-2015 11:02 AM
What's the difference between KK and KJ? rxmxsh KJ Liberty Forum 10 06-22-2009 03:21 PM
what is the difference between 4.7's jeepthing04 KJ Liberty Forum 4 01-11-2007 08:50 PM
New tire's - what a difference! Red Hackle KJ Liberty Forum 11 06-08-2004 05:12 AM
