Anoying rear glass (ready to smash it) - Page 2 - JeepForum.com
post #16 of 23 Old 07-05-2012, 08:34 AM Thread Starter
NEKVT
bran new
Originally Posted by WillieWildcat View Post
I assume you've tried hosing the whole assembly down with a grease and dirt cleaner and blow-drying it out? I had this problem with the latch that held the whole back gate closed. Turned out that my dusty road finally got to it one day.
As i was saying above these are all bran new parts... no dirt at all
NEKVT is offline
post #17 of 23 Old 07-05-2012, 08:39 AM
WillieWildcat
Ah, missed that. Sorry.
1999 Cherokee, 4.0L, 731k
2005 Wrangler, 4.0L, 70k WRECKED
1992 Cherokee, 4.0L, 174k SOLD
WillieWildcat is offline
post #18 of 23 Old 07-05-2012, 08:51 AM Thread Starter
NEKVT
no problem
no problem.... but man i have replaced everything.... all i can do is try shimming those hinges i guess....
NEKVT is offline
post #19 of 23 Old 07-05-2012, 08:52 AM Thread Starter
NEKVT
just for giggles
I have literally pulled every fuse and checked it... but is there a specific fuse that is related to that damn latch?
NEKVT is offline
post #20 of 23 Old 07-05-2012, 09:02 AM
afgd1
U need to keep clean if worn out replace. Hinge on glass it the gasket that needs to be replaced ck tail gate so it's not hanging low on one side. Had to re adjust it on mine 2xs now
afgd1 is offline
post #21 of 23 Old 07-06-2012, 05:26 AM Thread Starter
NEKVT
I am sorry i dont understand..... its the hing on the glass? the gasket under it? Thats whay i was going to put a shim under.
Please tell me more.
NEKVT is offline
post #22 of 23 Old 07-09-2012, 08:50 AM Thread Starter
NEKVT
After messing with it more it seems like it has somthing to do with the swing gate alignment. It seems like when the swing gate is shut it goes in too fas, and the loop on the flip glass cant quite push back far enough on the latch to make it click shut.
NEKVT is offline
post #23 of 23 Old 07-10-2012, 10:18 AM
northenhill
2006 KJ Liberty
One of our work Jeep Libs, a 2003, its rear door/glass started malfunctioning after a couple years in service. Would close the gate and glass would bonk against the latch mech. inside the door. Took off the interior cover to the gate and kept a screwdriver in the back for releasing the spring in the latch mechanism. Not sure on the mech. terms, but seemed a slot between flanges on the latch unit we easily pryed would release spring tension and latch mech. would swivel/accuate to accept window latch. This problem was intermittent and went on for years stringing along on this truck. At the least, was a good field remedy. This wasnt my primary shift truck, so I dont know and doubt if it was diagnosed or even repaired correctly ever to tell you any final, proper resolution. But, of course we lost the plastic interior gate piece in the shop somewhere so it stayed open/exposed for good.
northenhill is offline
rear glass hatch, keeps opening on its own xstratagoof KJ Liberty Forum 8 03-02-2013 01:23 AM
I need to buy a rear glass latch wjbjsmith KJ Liberty Forum 0 11-25-2010 10:09 PM
Rear Glass bnrboy775 KJ Liberty Forum 7 10-10-2010 06:22 AM
rear glass light goyle73 KJ Liberty Forum 1 08-12-2010 05:17 AM
Rear Flip Glass JeepLibertyNYC KJ Liberty Forum 9 05-18-2002 07:00 PM
