#1 | |
Alignment issues
Hey guys. I recently bought the wife an 03 Liberty. It pulls to the right. Had the tires rotated, and aligned, still pulls, not as bad, but?? Any thoughts?? I really appreciate any input.
Shawn 2002 TJ 2003 KJ |
#2 |
Typical Jeep problem, have the alignment redone and have them add more positive caster on the passenger side(@.5 degree) other then that a slight drift or pull to the right is normal due to the fact that there are no perfectly flat roads they all have a crown to them and that causes a pull.
#3 | |
I do alignments daily and if its not right....well its not right. If you post your alignment final numbers I can evaluate them for you too. Brakes and tires can also cause a pull so i am not saying the shop is at fault, just that if they were instructed to fix the pull then they haven't done that. If they were told to do an alignment then they were not going after a symptom and only made sure the specs are within tolerance. |
#4 |
Mine has always pulled to the right. Ive had many alignments performed..
#5 | |
pull to the right
#6 | |
Ill try driving on the left side to see if it pulls to the right still. ![]() |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
