Access for replacing oil pressure switch - JeepForum.com
post #1 of 4 Old 09-25-2013, 12:21 AM Thread Starter
AVR2
With the clutch fan and e-fan removed, is there enough access to change the oil pressure switch on the 3.7? Or do you have to go in from the driver's side wheelwell?
I'm going to be replacing my belt and tensioner soon, so I'll have the two fans out, and I figured I could replace my failing oil pressure switch at the same time.
AVR2 is offline
post #2 of 4 Old 09-25-2013, 03:36 PM
USPLiberty
I remember going in from the bottom on my Jeep and I had to remove the oil filter. After that, there was a good amount of room to work with.
USPLiberty is offline
post #3 of 4 Old 09-25-2013, 03:56 PM
olliehopnoodle
1982 FSJ Cherokee
With the fans out its easy to get to.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #4 of 4 Old 09-25-2013, 11:06 PM Thread Starter
AVR2
Cool, thanks.
AVR2 is offline
