AC/Vent Problems! - JeepForum.com
post #1 of 9 Old 03-20-2012, 10:06 PM Thread Starter
tilljo
2006 KJ Liberty
AC/Vent Problems!
My 2006 Jeep Liberty has problems with intermittant AC airflow. Sometimes I have the AC on with normal airflow and then at random times the air will almost stop flowing from the vents (The air often stays cold too). The odd thing is that I will still hear the air flowing inside the system, it just won't be coming out the vents anymore. It's like some door within the system closes randomly. When I redirect the air through the floor vents, or defrost etc, I notice that the slight airflow changes to those settings yet fails to come out the vents except for a slight amount. What could this be?
tilljo is offline
post #2 of 9 Old 03-20-2012, 11:49 PM
socks
2016 JK Wrangler
You might have a vacuum leak somewhere.
Or one of the vacuum hoses has come off of its mounts.
Fully loaded 2016 Black Wrangler JK Unlimited Rubicon X
socks is offline
post #3 of 9 Old 03-22-2012, 01:48 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
The heating-A/C system is a blend-air type system. The two blend-air doors control the amount of conditioned air that is allowed to flow through, or around, the heater core. This single zone heating-A/C system uses only one blend door actuator.
The A/C system is designed for the use of a non-CFC, R-134a refrigerant and uses an A/C evaporator to cool and dehumidify the incoming air prior to blending it with the heated air. A temperature control determines the discharge air temperature by operating the blend door actuator, which moves the blend-air doors. This allows an almost immediate control of the output air temperature of the system. The two mode door actuators operate the mode-air doors which direct the flow of the conditioned air out the various air outlets, depending on the mode selected. The recirculation door actuator operates the recirculation-air door which closes off the fresh air intake and recirculates the air already inside the vehicle. The blower motor controls the velocity of air flowing through the HVAC housing assembly by spinning the blower wheel within the HVAC housings at the selected speed by use of the blower motor resistor.
above information taken from service manual
JeepCares is online now
post #4 of 9 Old 03-22-2012, 06:46 PM Thread Starter
tilljo
2006 KJ Liberty
[/I]
How do the door actuators work? Are they run by vacuum or otherwise...?
Thanks for your input!
tilljo is offline
post #5 of 9 Old 03-23-2012, 06:40 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
The heating-A/C system uses two vacuum operated mode door actuators (1) to control the movement of the mode-air doors within the HVAC housing.
When vacuum is supplied by the A/C-heater control to the vacuum connector (3) on one side of the defrost/floor actuator or the panel door actuator, the actuator rod is pulled into the actuator, which moves the mode door lever and mode-air door in one direction. When vacuum is supplied by the A/C-heater control to the other side of the actuator, the rod moves the mode-air door in the other direction.
The mode door actuators are retained to the HVAC housing by an integral mounting provision (2) and can be accessed for service from under the driver side of the instrument panel.
The mode door actuators cannot be adjusted or repaired must be replaced if found inoperative or damaged.
post #6 of 9 Old 07-14-2013, 11:35 AM
DonaS12
2005 KJ Liberty
Did you ever solve this AC airflow problem? I have a 2005 Liberty and I have had this problem for a while now, hoping to figure out the problem.
DonaS12 is offline
post #7 of 9 Old 07-14-2013, 04:00 PM
streetglideok
2005 KJ Liberty
Is it all the time, or is it intermittent? That can make a big difference on what it could be. It can be a mode door problem, or it could be an evaporator frosting over.
streetglideok is offline
post #8 of 9 Old 07-15-2013, 07:41 AM
rangerr47
2012 KK Liberty
I just took my 2012 Liberty on its first long trip , Texas to NYC...The first day about half way through the day, this happened to me. I was pissed and really thought about calling off the trip, I must have AC...I turned it off for about 10min and then turned it back on and it was ok, it did this one more time later that day. Then for the rest of the trip it never did it again. It has never done this before, but Im usually only driving for maybe an hour tops.
Like he said, it will still be cold , but its like the vent is blocked, no air hardly comes out at all. And if you leave it on like this for a while, it will start blowing hot air and I could smell it getting hot, like electrical burning almost.
I have 5k left on my warranty so I was thinking about taking it in to be checked out.
rangerr47 is offline
post #9 of 9 Old 07-15-2013, 07:36 PM
streetglideok
2005 KJ Liberty
Sounds like a frosted over evaporator. If there is an undercharge of the a/c system, the evaporator will get colder than it is designed to, freezing the condensation on the evaporator. It'll build up to the point no air can pass thru it anymore. Only way to fix it is to have a full recovery and recharge of the system. Temporary fix is to turn off the a/c and leave the fan blowing on it. It'll eventually thaw out.
Dash Air Vent Covers Brad1972 KJ Liberty Forum 9 08-20-2016 08:43 AM
About the Pro-Vent on the diesel LibertyCRD KJ Liberty Forum 57 02-12-2013 11:16 AM
air vent problem eimoh KJ Liberty Forum 8 07-05-2006 02:44 PM
vent visors??? jimm KJ Liberty Forum 3 03-12-2004 07:19 AM
please allow me to vent missk KJ Liberty Forum 22 03-08-2004 12:51 PM
