Quantcast 60,000 Mile Maintenance Information/Suggestions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 60,000 Mile Maintenance Information/Suggestions
Old 11-17-2009, 11:13 AM   #1
osargd
2004 KJ Liberty
@ 60K Miles Jeep suggests that the following maintenance be done:
1. Engine Oil and Oil Filter
2. Replace/Clean Air Filter
3. Spark Pulgs
4. PCV Valve
5. Transmission Main Sump Pump
6. Drive Belt
7. Drain/Refill FRONT and REAR Axel fluid
8. Drain/Refill Transmission Fluid
9. Drain/Refill Transfer Case Fluid
does anyone have any recommendations on Oil/Filter, Air Filter, SPARK PLUGS (much debated topic) , Axel Fluid, Tranny Fluid, and Xfer case fluid? Are there any products out there that you recommend or DO NOT recommend? Just trying to make my Jeep age well...
osargd is offline   Reply With Quote
Old 11-17-2009, 12:41 PM   #2
Elt31987
Elt31987's Avatar
2008 KK Liberty
I always stick with Mobile 1 5W20 with a Mobile 1 Filter. K&N for the drop in filter. Im using E3 plugs but havnt noticed anything different so i would stick with the dealership plugs if they have worked for you. As for the rest i dont know, others will chime in
2008 KK Liberty
Inferno Red
Daystar 2" Spacer Lift With SkyJacker Hydro Shocks
JBA Gen 5.5 Upper Control Arms
Rokmen Riddler 8.25 Differential Cover
2 KC Slimlite 100 Watt Driving Lights on JK Light Bar
245/75/16 All Terrains
Mopar Front Tow Hooks
Mopar Rear Tow Hook
Mopar Skids
Elt31987 is offline   Reply With Quote
Old 11-17-2009, 01:43 PM   #3
LibertyTC
2004 KJ Liberty
60k lists...
I would use synthetic for all the oils/gear lube, and include power steering flush/ brake fluids, and battery /distilled water level if applicable.
Add to that list the belt tensioner when replacing the serpentine belt.
Also before spark plugs, clean the throttle body/emission service.
Inspections of front and rear suspension/exhaust.
Normally I also would check/change wiper blades, and exterior lights and tires check.
I normally just use mobil1 5-30 with a 1" nut on the bottom of a K&N filter for easy removals.
I use Purolator air-filter.
Even though you are draining tranny make sure you do the filter there...
Hope this helps. ...good luck on the major service tune up...
LibertyTC is offline   Reply With Quote
Old 11-19-2009, 10:17 AM   #4
aszalan
note that this 60k maintenance is for vehicles following schedule "B"
Schedule “B” — Gasoline Engines
Follow schedule “B” if you usually operate your vehicle
under one or more of the following conditions.
• Day or night temperatures are below 32°F (0°C).
• Stop and go driving.
• Extensive engine idling.
• Driving in dusty conditions.
• Short trips of less than 10 miles (16.2 km).
• More than 50% of your driving is at sustained high
speeds during hot weather, above 90°F (32°C).
• Trailer towing.
• Heavy loading.
• Taxi, police, or delivery service (commercial service).
• Off-road or desert driving.
• If equipped for and operated with E-85 (ethanol) fuel.
schedule "A" 60k maintenance (which is none of schedule B) requires:
changing oil and oil filter
rotate tires
inspect air filter
inspect pvc valve
change spark plugs
inspect drive belt
replace antifreeze
Originally Posted by shocka59 View Post
Go ahead and put a locker in the 35. I feel like it helps to keep you from breaking in certian situations.
aszalan is offline   Reply With Quote
Old 11-19-2009, 11:04 AM   #5
autoboy454
autoboy454's Avatar
and any time you rotate tires it is a good idea to take a quick look at the life left on your brake pads and rotors.
www.MassKrawlers.com
Love to wheel? Live in/around Massachusetts? Check us out!
autoboy454 is offline   Reply With Quote
Old 11-20-2009, 07:13 AM   #6
PhotograJeep
2008 KK Liberty
honestly, I just use regular oil at the dealership. I am told that every 5k is how often to change it, however, I change it every 3k. you may ask, "Why?" Well, my oil change is only $12.95. So going 6k on $25 or 6k on synthetic at $55 and up, is not much of a toss-up for me. I will always keep it changed, so it is ok to use regular.
I probably only need to use schedule b, however, I think I am going to stick with schedule a for harder driving, because, I never know how rough I may be with it in the future.
Photographer and Jeeper, Ken. 08 KK Custom Crossbars.
[IMG]http://i884.photobucket.com/albums/ac47/PhotograJeep/IMG_3212OurCarMotion.jpg[/IMG]
PhotograJeep is offline   Reply With Quote
Glock Forum
