4wd Problems - JeepForum.com
post #1 of 4 Old 02-07-2013, 08:03 AM Thread Starter
jeepkj617
2008 WK
4wd Problems
Every time I shift into 4wd hi, there is a speed dependent clunk noise that comes from the front end. There seems to be a little bit of play in the drive shaft coming out of the t-case into the front diff, so I was thinking it might be the u-joint?
When in 4wd low, I get the same noise, except it occurs at a much higher rate at the same speeds as 4wd hi. Could this actually be a transfer case problem?
"What do you mean it don't work? Just hit it with a bigger hammer!"
Thinking about buying a Cobra® 29-LTD 2-Way 40-Channel CB Radio. Anyone have install/antenna suggestions?
jeepkj617 is offline
post #2 of 4 Old 02-07-2013, 08:40 AM
tommudd
2004 KJ Liberty
No u joint in the front driveshaft
Have you looked at the rear boot on the front driveshaft?
Could possibly be the issue
easy fix
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
05 KJ
tommudd is offline
post #3 of 4 Old 02-07-2013, 08:50 AM Thread Starter
jeepkj617
2008 WK
Good to know hah I havnt actually had a chance to really look at it, plus its been so cold and I don't have a garage or anything.
I'm not entirely sure what to look for there, but I did some searching now that I know what/were it is. Looks like the whole joint needs to be replaced if that's the problem?
post #4 of 4 Old 02-07-2013, 09:05 AM
tommudd
2004 KJ Liberty
You can get a repair kit thats about 65-70 bucks
hardest part is removing the driveshaft and even thats not very hard to remove
MUDD'S MOTORSPORTS
05 KJ
tommudd is offline
4wd , clunk noise , transfer case
