4wd part time and full time how to change - Page 2 - JeepForum.com
post #16 of 28 Old 01-24-2013, 01:07 PM
EP267
Originally Posted by TwoBobsKJ View Post
You could have either transfer case - the model you have doesn't dictate which case comes with it.
Does it have 5 positions on the handle - or 4?
If 5 (2WD, 4 Part Time, 4 Full Time, N, 4 Lo) then you have a SelecTrac Full Time case. If the handle has 4 positions - no Full Time - then you have the Command Trac case and you should NOT drive on dry pavement in 4 High.
Look at your Jeep and let us know what you have if there are any more questions about 4X4 operation.
Bob
Ok, I will look at them will let you know it tomorrow.
Thank you very much!
EP267 is offline
post #17 of 28 Old 01-25-2013, 08:22 AM
EP267
It has 4 positions. 2Hi, 4HI , N, 4LO
EP267 is offline
post #18 of 28 Old 01-25-2013, 08:24 AM
01CHEEKEE
Then you do not have selec-trac...and do not have "full time" 4wd
01CHEEKEE is offline
post #19 of 28 Old 01-25-2013, 08:44 AM
EP267
Ok.. What is the difference between 4HI and 4Lo?
EP267 is offline
post #20 of 28 Old 01-25-2013, 09:29 AM
01CHEEKEE
4hi can be used up to ~55 and switched on/off on the fly by simply lifting your foot off the accelerator momentarily.
4lo is for off roading/mud/crawling and has to be engaged by stopping, place gear shift into N, putting in 4 low, then driving. And you shouldn't go over ~10-15 I think it is...
If there's is an actual mechanical difference internally as far as locking diff's, I don't know
4hi is good enough for all normal driving conditions...
post #21 of 28 Old 01-25-2013, 10:37 AM
EP267
I understand now. Thank you very much.
Yesterday's sound of car , I realized; it couldn't shift to 4lo, it had been on "N".. ooopps.. ( I am a women )
But I learned much more..
Much much appreciated!!!
EP267 is offline
post #22 of 28 Old 01-25-2013, 07:31 PM
tjkj2002
2002 KJ Liberty
4 low gives a additional 2.72:1 gear reduction.
Never use part time 4wd or 4 low on dry/wet pavement.The t-case is locked forcing the front and rear driveshafts to turn the same speed no matter what and your geared slightly different in the front and rear diffs so you will get binding even driving in a straight line.No factory lockers in a KJ ever so you will not have to deal that issue untill you add them yourself.
tjkj2002 is offline
post #23 of 28 Old 01-25-2013, 08:20 PM
02libbyfirstcar
2002 KJ Liberty
I've never heard of this before however the way you describe it makes since. So what about if I get like 1" of snow?
02libbyfirstcar is offline
post #24 of 28 Old 01-25-2013, 09:39 PM
tjkj2002
2002 KJ Liberty
2wd or if you have the select trac you can use the full time 4wd option.
Buy better tires and you will not need 4wd at all.In 2 winters here in Colorado I have yet to even lock in my front hubs(mine is far different then yours and far from stock) so no 4wd even for 12" of snow.Haven't needed it unless I'm on the trail.
tjkj2002 is offline
post #25 of 28 Old 01-26-2013, 06:04 AM
02libbyfirstcar
2002 KJ Liberty
Well I haven't slipped yet in 2wd with command trac. However I do have new tires coming on Monday. And yes I am very aware that you are different from mine. A picture of your jeep is the background on my computer haha
post #26 of 28 Old 06-03-2013, 08:35 AM
jedi105
2005 KJ Liberty
What is better for deep soft sand? 4HI or 4LOW. And what tire pressure? I used 4HI and 16 lbs last time but I felt like I was bogging down a bit especially going from rut to rut. I am also using standard passenger tires (versus the knobby types). The bogging down may have been my fault as I was very nervous so I may not have been accelerating properly or staying in the right ruts. This was my first go at off road and the ruts were huge leading me to believe the sand was very deep.
jedi105 is offline
post #27 of 28 Old 06-04-2013, 09:02 AM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
When off-roading in sand, mud, etc. most use 4-LO. However, often when running on sand such as on the beach you like to get up to speed - and 4-LO should only run up to about 15mph. Any faster than that and you're turning some serious RPM's.
Work on your technique a bit more. As you said it could be the acceleration and use of the throttle that caused the Jeep to bog down vs being in the correct TC range.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #28 of 28 Old 06-05-2013, 07:36 AM
jedi105
2005 KJ Liberty
thanks for the info. Going out again this weekend so maybe with time I'll become more confident. I love my Jeep but as it is my first one, I have no idea what I can do with it yet. Friends tell me that I can really dish out the punishment but I guess until I try something and see I can for myself, then I wont believe it. I'm really looking forward to when I can go mudding and get her really dirty.
jedi105 is offline
Full Time/Part Time 4wd? Buffalo Chip KJ Liberty Forum 7 12-04-2013 08:11 PM
part time light on when not in part time ytt1300 KJ Liberty Forum 10 01-24-2011 12:30 AM
How do I shift from part time to full time? BjBnet KJ Liberty Forum 6 04-10-2008 12:19 PM
Full time 4X4 Bacchus KJ Liberty Forum 12 01-05-2008 06:33 PM
Part time light on all the time sharhack KJ Liberty Forum 2 07-31-2007 10:58 AM
