4WD Not Engaging - JeepForum.com
post #1 of 14 Old 12-22-2005, 03:50 PM Thread Starter
jjo
4WD Not Engaging
What would cause my 4WD not to engage (Full or Part) unless I briefly drive in reverse first?
I'm taking it in for an inspection next week to the dealership, and I told them about this issue, but I'd like to point them in some general direction first.
'05 Renegade; Fulltime 4WD; Sirius; RB1 Navigation
Post your Jeep pics for free via email @
jjo is offline
post #2 of 14 Old 12-22-2005, 04:15 PM
usswasp
1994 XJ Cherokee
Binding pressure ... check your tires for correct pressures. Does the shifter move easily or with difficulty when you do finally get it into 4wd by backing up?
94 XJ Country, 4L HO, AW4, NP 242, 115k miles
08 Jeep Patriot, FD I CVT2 2.4L
02 KJ Sport traded ... I miss the ole' girl, except when I stop at the gas station
usswasp is offline
post #3 of 14 Old 12-22-2005, 04:18 PM Thread Starter
jjo
The shifter seems fine regardless.
All tires have 35psi.
The front wheels do not spin when in 4WD unless I back up briefly, then put it back in drive.
jjo is offline
post #4 of 14 Old 12-22-2005, 04:24 PM
usswasp
1994 XJ Cherokee
Hmmmm ... I guess I don't know then. I do remember that our Liberty didn't come out of 4wd (especially full-time) very easily when we first got it. I think the previous owner did not use it much and it was just a bit stiff and needed to be worked a few times. One winter with snow in Erie, PA running full-time a lot cured that problem. Now it shifts easily.
usswasp is offline
post #5 of 14 Old 12-22-2005, 06:35 PM
WXman
My '05 takes several seconds to engage once i shift to 4-high. Sometimes i do back up to make it engage but i found that if i wait several seconds it will go ahead and go in. i have no clue why.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #6 of 14 Old 12-22-2005, 06:38 PM
WXman
oops...double post
WXman is offline
post #7 of 14 Old 12-22-2005, 09:25 PM Thread Starter
jjo
Actually, I just checked my pressure. They are all 29.5 psi. At what point does the pressure "warning" light show on the dash?
jjo is offline
post #8 of 14 Old 12-22-2005, 10:17 PM
auggy
This might seem stupid, but do all '05 renegade's have the option of full time 4wd? I assume that 4wd lo is full time but that's not what I'm looking for ...
'05 KJ Renegade 3.7L
Bridgestone Dueler A/T Revos
Lost Member Number: 051898
auggy is offline
post #9 of 14 Old 12-23-2005, 12:21 AM
brewcider
The 05 Renegades have CommandTrac standard. SelecTrac is optional on the "D" package.
CommandTrac has:
2-Hi
4-Part-Time
Neutral
4-Low
SelecTrac has:
2-Hi
4-Part-Time
4-Full-Time
Neutral
4-Low
4-Low is not Full Time, it is Part-Time, meaning there will be binding on pavement.
To help with the shifting problem, sometimes I throw the tranny into Neutral before shifting the transfer case. This I think takes pressure off the transfer case and make it slip into 4 wheel drive easier.
Hope this helps!
sold - 2005 Liberty Limited CRD, 22G Package, Atlantic Blue, fully loaded.
2007 Grand Cherokee Limited Diesel 4x4
brewcider is offline
post #10 of 14 Old 12-23-2005, 03:04 AM
LEDFoot
Are you doing this with the jeep on a lift or something?
It's pretty common that it takes a little bit for the transfer case to engage/disengage, especially when you are locking or unlocking it (which you would be doing every time you shift into 4wd with a command track).
Sometimes it "pops" in when after you drive for a few yards, or put it in reverse or something like that.
This happens especially on newer trucks because the parts are not quite "worn in" yet.
LEDFoot is offline
post #11 of 14 Old 12-23-2005, 08:22 AM Thread Starter
jjo
Thanks for the suggestions. I'll have to investigate further...
jjo is offline
post #12 of 14 Old 12-24-2005, 09:54 PM Thread Starter
jjo
Ok, here's what I've determined. And if this is the case, then I feel kinda stupid bringing it up in the first place...
If I am standing still, in drive, foot on the brake, and shift it into either 4WD full or part time, it won't engage.
In the same scenario, but I put it in 4WD while in neutral then shift into drive, it engages.
While driving and I shift into 4WD, it engages.
Is this normal conditions for a Liberty? I don't seem to remember my '00 Cherokee (w/Command Trac) behaving this way.
FYI, I tested this on an icy slope.
jjo is offline
post #13 of 14 Old 12-24-2005, 10:56 PM
usswasp
1994 XJ Cherokee
Its okay. You really should be moving to engage the 4wd properly. It won't respond well sitting still. The gears need to mess properly and when they are moving you had the best chance of them aligning properly. I could shift a 231 sometimes at a stand still but never been able to shift a 242 at a stand still and actually get lucky that all the gears line up. That's why I tell my wife you need to know before you're in trouble that you need 4WD. If you get stuck its going to be harder to shift into 4wd, not impossible, but harder.
usswasp is offline
post #14 of 14 Old 12-25-2005, 06:32 AM
gonz165
It sounds like your 4WD is working fine. Try to be moving when you engage. The instructions on how to properly engage 4WD are in the owner's manual. If you haven't already, you should read it to familiarize yourself with your vehicle.
gonz165 is offline
