Quantcast 4WD indicator light malfunction - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 4WD indicator light malfunction
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 11-15-2004, 01:11 PM   #1
marahee7
This past weekend I used my 4WD in snowy conditions. I used both 4-HI and 4-LOW depending on what condition I was driving in. After being stuck momentarily and switching between 4-Low and 4-HI I began reciving the following indication.
In 4HI - the indicator "PART-TIME" which is normally displayed is NOT.
In 2HI - the indicator "PART-TIME" IS displayed when normally it is NOT.
Before returning to the paved/cleared roads I made sure that I was not in 4WD despite the indication on the instrument panel.
Any ideas why this happened and how to correct it? Thanks.
marahee7 is offline   Reply With Quote
Old 11-16-2004, 04:36 PM   #2
MunkyRentsch
my guess is u were switching around too much between 4lo 4hi and 2hi,
if it hasn't corrected itself by now- take it to the dealer
but i would have shut the car off - put it back in 2hi until it read the right way-
unless u were in really heavy snow traveling like under 15mph i woulnd't use 4lo- just my opinion but i don't use 4lo unless i'm trying to get thru my driveway after it was plowed
4lo really revs up the engine alot- i've found it easier to leave it in 4hi for better maneverability and shift the trans to 2nd gear or low gear in the Auto Trans
can't wait to get some snow it PA, praying for a few blizzards and at least more than a foot of snow total this winter
last year we got jipped - it was flurrying last week but thats nothing
don't know if my suggestions were all right- but i felt bad no one answered your post
[COLOR=Black]2005 Jeep Grand Cherokee Rocky Mountain Edition 4WD 4.7L V8 Inferno Red[/COLOR]
MunkyRentsch is offline   Reply With Quote
Old 11-16-2004, 05:28 PM   #3
2004CAKJ
I think my owners manual says not to go over 15mph in 4LO. I don't imagine that if you stuck you would be doing that though.
2004CAKJ is offline   Reply With Quote
Old 11-18-2004, 09:45 AM   #4
Timmy.o.tool
you should never need 4 wheel low in snow. it is for mantaining a steady crawl with the engine rpms up where the power is... IE on a tight trail with some hard opsticles on it. I hardly ever even put any of my vehicles in 4wd even in the snow...
Your wheels have to be able to slip when your in 4wd so if you are solid pavement it can mess up the system. Plus you should come to a complete stop ever time you engage and disengage never do this while moving. I know they say you can but if you do you are trying to make parts that weren't moving go 20 mph instantly.... not a good thing for longevity.
you all like your liberties so far?
1989 YJ Underland
2003 WJ Overland
Timmy.o.tool is offline   Reply With Quote
Glock Forum
