4 wheel drive noises.....04 Liberty - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 4 wheel drive noises.....04 Liberty
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 12-23-2008, 03:17 PM   #1
jeeprscreeprs04
2004 KJ Liberty
OK so I'm new to this forum and have been searching for some answers. I have an 04 with 84000 miles. I've had it for just over a year. Last winter was the 1st time I used the 4 wheel and it seemed to make kind of a loud humming noise, seemed weird for being a newer vehicle and all, but I thought nothing of it. Didn't use 4 wheel all summer and then over the last month we have gotten significant amounts of snow. I used 4-hi on the highway going to work and it seemd the same as last winter. Coming home the humming noise seemed louder. Anyone elses make this noise? If not what do you think it is? I have been avoiding using it as much as possible but I have to in my driveway. Now it makes a clicking noise form the front end? I can't tell if its from the front CV joints or transfer case? Anyone have a guess as to what this could be and about how much to fix?
Thanks
jeeprscreeprs04 is offline   Reply With Quote
Unread 12-23-2008, 07:07 PM   #2
LoneLiberty
2004 KJ Liberty
Thanks
Clicking is generally the CV's going out. You can get reman. from Napa for $75.00 ea. with core trade.
Slightly Modified O4 Liberty LTD
Pix/Mods:http://www.cardomain.com/ride/531173
LoneLiberty is offline   Reply With Quote
Unread 12-23-2008, 11:09 PM   #3
bearster18
No neccessarily true. At the dealership I work at the front driveshaft tends to be a problem alot of the time. It will make a clicking noise like a CV will too. Best thing to do is put it up on four jack stands securely, put it in 4wd then put it in drive and start spinning the tires to pin point it that way
bearster18 is offline   Reply With Quote
Unread 12-24-2008, 05:07 AM   #4
LoneLiberty
2004 KJ Liberty
Good call on the driveshaft possibility, and a lot less work if that turns out to be the problem.
Unread 12-24-2008, 05:22 AM   #5
bearster18
I didn't think of it when I posted but to the OP. Put it in 4 LO and if you get the same click then you can narrow down to a CV or Driveshaft. If It doesnt make the sound in 4 Lo then I would start suspecting the Transer case. Also its not advised to run 4 HI all the time unless the roads are slick. If they are dry then you can destroy the driveline on your vehicle. Thats straight from chryslers mouth.
Unread 12-24-2008, 12:44 PM   #6
jeeprscreeprs04
2004 KJ Liberty
ok thanks for the info....I'll see if I can find some time to dig into it this weekend. If it is the driveshaft, can it be fixed or do I have to get a new one?
As far as running 4-HI, I only run it in the snow when the roads are bad otherwise I'm playing in 2 wheel.
Again thanks and I'll keep you posted on the results.
Unread 12-24-2008, 04:58 PM   #7
LoneLiberty
2004 KJ Liberty
No known fix that I'm aware of. Options are a used from a junk yard, new from the dealer, or custom made with new yokes and u-joint repacements.
Unread 12-25-2008, 06:05 PM   #8
jeeprscreeprs04
2004 KJ Liberty
I used 4-LO this morning and it still makes the clicking noises.......
Unread 12-25-2008, 08:00 PM   #9
bearster18
Then I'd more than likely point at the driveshaft then BUT unless you can put it in the air and check it over its hard to say. IMO tho I'd say driveshaft typical problem associated with dodges, jeeps, ect.
Unread 12-25-2008, 08:20 PM   #10
DaveJKJ
2005 KJ Liberty
If you replace the front driveshaft use OEM or get one from NAPA......Do NOT get one from Autozone. Put them side by side when you do the swap and make sure they are EXACTLY the same.
War Veterans Jeep Group #31
Black Jeep Society #217
DaveJKJ is offline   Reply With Quote
Unread 12-26-2008, 12:25 PM   #11
CmdrK
2008 KK Liberty
I found this Tech Tip listed with the front and rear driveshaft part numbers for the 04s.
PLEASE PROVIDE A COPY OF THIS SHEET TO THE SERVICING TECHNICIAN.
PRIOR TO ORDERING THIS PART, THE FOLLOWING MUST BE VERIFIED:
Tech Tip Part Description: Liberty Dirveline Components
Tech Tip Description: Liberty 48-52 mph vibration/drone or high speed rear axle noise/whine.
ISSUE 1 If ordering this part for a 48-52 mph (38-39hz) driveline vibration/drone concern, please contact...
ISSUE 2 If you are ordering this part for a high speed rear axle noise/whine concern, please verify that rear axle backlash is within specifications (.005-.008). If .011 or greater, reset and road test before ordering parts. If vehicle is equipped with 3.7L, automatic, 4X4, please verify that the rear propshaft part number is 52853119AB.
Mods include: full size spare, Mopar front tow hook. Mopar skid plates, rear recovery mount (trailer hitch with D-ring).
RED JEEP CLUB MEMBER #145
LIBERTY LOVIN CLUB MEMBER #4
CmdrK is offline   Reply With Quote
