3.7L Liberty engine developed loud knock - JeepForum.com
post #1 of 11 Old 02-19-2011, 09:41 PM Thread Starter
Jeffin8tor
2002 KJ Liberty
Hello, we have a 2002 Liberty with the 3.7L V-6 engine with 178,000 miles that just developed a loud knock in the engine. To me it sounds like it's internal, (possibly a connecting rod bearing?), but wanted to ask if anyone knows of any common things to look for before I get into this too deeply?
Thanks!
Jeff
Jeffin8tor is offline
post #2 of 11 Old 02-21-2011, 09:53 PM
95BadBoy
First post - welcome to JF -
Chances are are good that your guess is correct. Not being a heavy mechanic - possibly another member will be able to jump in with a bit more advice.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #3 of 11 Old 02-23-2011, 08:15 PM
Liberty&Freedom
2003 KJ Liberty
Last winter I had a rocker arm come loose... Made a terrible racket. Turns out this can happen on these jeeps, and it's not a major repair as long as nothing else was damaged. (couple hundred bucks was all for me.)
What could be better than Liberty & Freedom ???......Driving a Jeep that is both?!?!?
2003 Freedom Edition
Liberty&Freedom is offline
post #4 of 11 Old 12-24-2013, 09:30 PM
raineydoug
2003 KK Liberty
3.7 liter verry bad knock in engine
bought 2003 liberty 3.7l. stopped running withpreviouse owner. checked codes and came up bad crank sensor. removed sensor and entire end was broken off. installed new sensor fired right up but knocks soooo bad sounds like two rod coming out. what could it be?
raineydoug is offline
post #5 of 11 Old 12-25-2013, 07:12 AM
streetglideok
2005 KJ Liberty
From your description, probably a rod flopping around in the engine, and/or a crank flopping around. The key piece of evidence is the crank sensor. The end was damaged, and that is a dead giveaway to an internal problem with the noise you have.
streetglideok is offline
post #6 of 11 Old 12-25-2013, 08:48 AM
raineydoug
2003 KK Liberty
Thanks! Sounds like a fun job ahead! Merry Christmas!
post #7 of 11 Old 12-25-2013, 11:00 AM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
Here's what a bad rod bearing sounds like when the engine is torn down - I replaced my '03 engine with one from an '07 (after doing some mods to make it work with my Jeep's computer) and when I pulled my original this is what I found. It's the #6 cylinder:
Here's an overview of the engine swap.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #8 of 11 Old 12-25-2013, 05:59 PM
raineydoug
2003 KK Liberty
thanks Bob! You really gave a lot of useful information! how hard was that engine to get out? lucks like a lot of work at first glance.
post #9 of 11 Old 07-08-2015, 09:49 PM
Mcushman
I have a 2003 Jeep Liberty it started making a knocking noise and the machine at autozone throws a code of it being the spark plugs if the spark plugs were bad and misfiring would it knock? TIA
Mcushman is offline
post #10 of 11 Old 07-08-2015, 10:25 PM
Mcushman
Mcushman is offline
post #11 of 11 Old 07-08-2015, 10:34 PM
pentastarguy
2015 JK Wrangler
i would just put in new plugs and go from there.
pentastarguy is offline
'02 Liberty - loud snap from front end WO312 KJ Liberty Forum 5 06-26-2009 01:32 PM
02 Liberty LTD Knock When Accelerating MKaye02 KJ Liberty Forum 1 06-12-2009 04:31 AM
'02 liberty mechanical fan is loud Strorg KJ Liberty Forum 4 10-27-2008 07:58 PM
loud knock in engine sammiejoedee KJ Liberty Forum 2 01-20-2008 09:29 PM
is the FUEL PUMP on your liberty LOUD ??? soimcrazy KJ Liberty Forum 2 03-23-2005 03:21 PM
