2wd Lift? - JeepForum.com
post #1 of 27 Old 04-09-2013, 01:40 PM Thread Starter
Wpmclam
2wd Lift?
Has anyone on here lifted a 2wd Libby?
Wpmclam is offline
post #2 of 27 Old 04-09-2013, 03:51 PM
All3Sports
2004 KJ Liberty
Yheap.
Edit: sorry about the huge pics, first one is basic over view and 2nd gives a little look into the suspension = no front axle.
02 KJ Renegade - Totaled....
04 KJ Limited - OME 927/948 General Grabber AT2 247/75/16
All3Sports is offline
post #3 of 27 Old 04-09-2013, 04:14 PM Thread Starter
Wpmclam
That's pretty sweet. I don't know anything about lifting but for what I've learned on here. How high of a lift is that?
Wpmclam is offline
post #4 of 27 Old 04-09-2013, 04:31 PM Thread Starter
Wpmclam
This is basically what mine looks like, complete with steel wheels. I'm hoping to be adding to it. It was my mother-in-laws car so it's kind of rough. I put some new tires on it, street tires for now and they are the original factory spec. I must have some sagging in the front end because they nearly rub the wheel wells. Either that or the bumper is dragging cause it's been hit
Wpmclam is offline
post #5 of 27 Old 04-09-2013, 05:24 PM
tommudd
2004 KJ Liberty
You can do a 3.5 to 4 inch fairly easy
Same as doing a 4 wheel drive
whatever works for them works for yours
Some will try and tell you that you can lift it higher than a 4 wheel drive, but not so
you still run into the same issues with spring contact on the UCAs etc
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
05 KJ
tommudd is offline
post #6 of 27 Old 04-09-2013, 05:29 PM
tommudd
2004 KJ Liberty
mine on the right is a 4.25 inch lift, 265-75s and 4.10 gearing
one on the left is 3.75, 245-75s
MUDD'S MOTORSPORTS
05 KJ
tommudd is offline
post #7 of 27 Old 04-09-2013, 06:08 PM Thread Starter
Wpmclam
I found a ome 1.5 lift but couldn't find a 3 inch
Wpmclam is offline
post #8 of 27 Old 04-09-2013, 06:10 PM
tommudd
2004 KJ Liberty
They are advertised as a 1.5 inch lift for insurance purposes over in Australia , but you get about 2.25 to 2.5 inches with some extras like top plate and clevis you get over 3
Look at OME springs or Ironman both are good and ride close to the same
or look at the Econo kits at JeepinByAl which includes everything for a 3.5 -3.75 inch lift
MUDD'S MOTORSPORTS
05 KJ
tommudd is offline
post #9 of 27 Old 04-09-2013, 06:12 PM Thread Starter
Wpmclam
I don't know anything about this sort of stuff. Can you explain what top plate and Clovis means?
Wpmclam is offline
post #10 of 27 Old 04-09-2013, 06:14 PM
tommudd
2004 KJ Liberty
Top plate goes on top of the spring , 1/4 inch thick plate gives you 1/2 inch lift, clevis lift is when you leave the bottom of the front shock up out of the clevis 3/8 of an inch for 3/4 inch of lift
MUDD'S MOTORSPORTS
05 KJ
tommudd is offline
post #11 of 27 Old 04-09-2013, 06:17 PM Thread Starter
Wpmclam
Ah okay. Got it now, thanks. So would this work for what I want to do? http://jeepinbyal.com/jeep-liberty-k...ft-kit-kj.html
Wpmclam is offline
post #12 of 27 Old 04-09-2013, 06:22 PM
tommudd
2004 KJ Liberty
That would give you around 2.5 inches of lift over new stock height
MUDD'S MOTORSPORTS
05 KJ
tommudd is offline
post #13 of 27 Old 04-09-2013, 06:46 PM Thread Starter
Wpmclam
That'd be perfect for me. It being 2wd it will see more pavement than dirt
Wpmclam is offline
post #14 of 27 Old 04-10-2013, 10:24 AM Thread Starter
Wpmclam
Would I need anything beyond the kit in the above link and if so what do I need to get. Will have a shop install everything.
Wpmclam is offline
post #15 of 27 Old 04-10-2013, 10:29 AM
Griff1918
Yep I lifted mine with rk 3.5" lift. Looks good. But it you struts have over 40k on them order a new set of quick struts so you are not cruising with a new lift and old springs.
Griff1918 is offline
