Quantcast 2nd Oil Change..and Axle Fliud Change? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 2nd Oil Change..and Axle Fliud Change?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 08-18-2006, 01:16 PM   #1
rmnoonan
Liberty gurus,
I just dropped off my Liberty Sport CRD to the dealer for the 12,000 mile servicing. I usually get the oil changed, rotate tires, etc. But this time the manual says we should get the axle fliud drained and refilled. IS THIS NECESSARY? IT IS EXPENSIVE!!
rmnoonan is offline   Reply With Quote
Old 08-18-2006, 02:10 PM   #2
pbrutsch
Yes to both, it's about $ 400.
It's neither a Jeep nor a CRD thing, a 4x4 Toyota with a gas engine will need the same
[SIZE=1][b][i]Real[/i][/b] Jeeps don't need no stinkin' spark plugs![/SIZE]
pbrutsch is offline   Reply With Quote
Old 08-18-2006, 02:34 PM   #3
jeepjeepster
This depends on alot of stuff. Do you tow, offroad, do alot of hard accelerations? If so, then yes, they need to be changed. If not, then I would say its ok to wait till 24k or even 30k if you cannot put down the cash right now.
jeepjeepster is offline   Reply With Quote
Old 08-18-2006, 02:54 PM   #4
BVCRD
I'll be doing mine myself.
2006 Jeep Liberty Sport CRD
BVCRD is offline   Reply With Quote
Old 08-18-2006, 04:47 PM   #5
jeepjeepster
I also do mine myself, but everyone cant do that...
Old 08-18-2006, 05:13 PM   #6
rrubio
We all should be doing our own.This way you really know what you put in there,synthetic all the way.
rrubio is offline   Reply With Quote
Old 08-18-2006, 05:20 PM   #7
jeepjeepster
Yup, SYN is what I used!!
Old 08-18-2006, 10:22 PM   #8
Cowpie1
The Libby is such a sweet vehicle to work on, most owners could do these things themselves and save a bundle! At about 1500 miles, I changed out both differentials, transfer case, tranny, and engine oils and went synthetics throughout.
To avoid the RTV mess with the rear end, get the Chrsyler 8.25 gasket from
www.lubelocker.com
I did the entire job for one hell of a lot cheaper than the dealer would charge. It is suprisingly easy to work on the Libby. Only the tranny may be too complicated for some. For that, a good tranny shop will usually be less than a dealer. For everything else, do it yourself. I have not experienced a better vehicle to work on since my '79 Ford Bronco.
Cowpie1 is offline   Reply With Quote
Old 08-19-2006, 02:02 AM   #9
RFCRD
This is no more difficult than changing engine oil. Did everything at the same time for @ $260. This included using all synthetics and a pricey aftermarket rear diff cover with a real drain so I won't have to pull the cover next time. The lubelocker gasket is a good economical alternative. If you are willing to get dirty, do it yourself.
RFCRD is offline   Reply With Quote
Old 08-20-2006, 09:13 AM   #10
dthorpe
My manual states that the first axle fluid change is to be done at 15,000 miles, not 12,000. Your dealer is wanting to change it too early. At the hefty price of $400, I would stick with what the manual says!
dthorpe is offline   Reply With Quote
Old 08-20-2006, 02:13 PM   #11
x99j
i do it myself for the cost of the lube! and it is simple. if you try it it will be worth it.
99xj, 4.0, aw4, nv 231 d-30, 8.25. dessert sand pearl. former rent a car from Enterprise. great shape!
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
x99j is offline   Reply With Quote
Old 08-20-2006, 08:00 PM   #12
dthorpe
How is it done?
Old 08-21-2006, 07:04 AM   #13
x99j
i got a transer pump from any auto parts store to pump the back out, and then refill. the front has a hex drain plug to drain the front with. you can get her done in an hour. just make sure on the front you crack the fill plug loose first.
i think the transfer pump was like 15 dollars. just make sure it will pump thick gear lube.
Old 08-21-2006, 11:08 AM   #14
RFCRD
Originally Posted by dthorpe
How is it done?
Everything except the rear axle has both drain and fill holes. Rear axle requires either removing the rear cover and re-gluing (or installing a cut gasket) or using a suction pump inserted through the fill hole. My presonal preference is removing the cover on the first change so you can clean the break-in cuttings from the magnet on the bottom of the casting. Really not any more difficult than a basic oil change.
Old 08-21-2006, 11:31 AM   #15
rob92xj
1992 XJ Cherokee
www.lubelocker.com
Your Liberty was built with synthetic gear lube in the diffs. Sythetic gear oil is the recommended lube for the diffs and it should be changed @12-15000 miles or about once a year. 75W140 front and rear.
rob92xj is offline   Reply With Quote
Glock Forum
