Quantcast 2007 kj lift and tires for beach HELP me - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 2007 kj lift and tires for beach HELP me
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 07-27-2010, 06:17 AM   #1
goyle73
2007 KJ Liberty
i am looking to get a 2.5 inch lift and a new set of bigger tires i am now on 225/7516 stocks.... the guy at my local shop is suggesting a bds lift kit (any Good???) and as far as tire i want the most aggressive biggest that will fit but .... i plan on taking on the beach(IBSP in NJ) in loose sand alot ... as far as i know getting mud terraians would be a bad idea cause i ll dig in and get stuck...all the tires he showed me are kinda bland looking .... i don t wanna spend all this money and not see a big difference .... please someone help me out here
goyle73 is offline   Reply With Quote
Old 07-27-2010, 12:21 PM   #2
95BadBoy
BDS is an ~ OK lift. The most well talked about by owners that have a lift is the OME / Frankenlift for KJ's.
Tire wise - 245-75-16's would be the size you need. An AT tire would most likely do the job for what you mentioned.
05 TJ RME 42RLE with some things
05 KJ CRD GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded
FS or FT (2) JK Rubi 17" Moab Rims - really nice shape
Need JK Rear Spare tire bracket for project
95BadBoy is offline   Reply With Quote
Old 07-27-2010, 12:23 PM   #3
madrabbitt
BDS is one of the better quality lift kits.
The only kit they offer for the KJ is a 2 inch kit, with 2 inch front springs, 1.5 inch rear springs, front strut relocation brackets, and rear shocks.
The upfitter I do some work for has installed this specific kit on 4 KJ's for a police department with very good results.
Also, we used 245/75R16 tires, and they work well with this kit. We specifically used goodyear MTR's at the client's request, although that wouldnt have been my first choice for a sandy desert environment that these trucks see service in.
Anyway, these installs were done in 2006-2008, and as far as i'm aware, none of them have come back in for any breakage or damage to the suspension itself.
However, BDS has one of the best warranties in the business if anything does break.
MADRABBITT -SELLING THE WJ- Ham Radio Callsign:W5BNY Facebook Myspace Blog
Disclaimer: I am a HUGE advocate of responsible/legal wheeling and land usage. Any photos that I post of my vehicles, or wheeling trips are either taken on public-accessable land, or private land that I have permission to be on, either in a group, or individually. (Even constuction site, and power/gas line roads) I'm lucky enough to have a job that lets me wheel on roads that may not be open to the public. Please. Wheel Legally, and support land access groups.
PS: Installing HID's in stock housings is bad. Here is why.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline   Reply With Quote
Old 07-28-2010, 03:50 PM   #4
jamesdart
1978 FSJ Wagoneer
im looking to do the same. unfortunately i need tires asap. doing my brakes today. gotta get a new front driveshaft before i go out on the beach though.
jamesdart is offline   Reply With Quote
Old 07-29-2010, 03:11 PM   #5
FlyingLow
2007 KJ Liberty
PM sent. :thumbup:
07 KJ- 6 speed, 4 inch BDS/ Daystar lift, 35x12.5 m/t's, homebrew snorkel, muffler delete w/ straight pipe, way too many lights, and a loud system to drown out the JEEP noises.
FlyingLow is offline   Reply With Quote
Old 07-29-2010, 03:16 PM   #6
swtwomyn
2003 KJ Liberty
Hello!
I just had my front drive shaft replaced, I see the same guy has more! Go to Ebay item 270590640944. He worked with me on mine. FYI take it off to measure it...I had to send mine back and get another one because the mechanic measured it wrong. It's a very strong and much better drive shaft now! Have you been over to lostkjs.com yet?? Lots of good info there about lifts...I have the frankenlift 2 from boulderbars.com Good luck, have fun!
Tracy
swtwomyn is offline   Reply With Quote
Old 07-29-2010, 03:18 PM   #7
FlyingLow
2007 KJ Liberty
Madrabbit are you sure they're 1.5's in the rear? My kit came with 2 inch springs front and rear. I could be wrong but I believe the 1.5 inch rear is their spacer kit, not the suspension kit. X2 on the incredible durability though.
Old 07-29-2010, 03:29 PM   #8
tjkj2002
2002 KJ Liberty
Tracy
That type of front driveshaft will cause more issue in the long run then solve.It's the wrong type of driveshaft for the front of a KJ,and yes there is a difference.You just can not throw a u-joint driveshaft on without 1st making modifications for that shaft to work.
tjkj2002 is offline   Reply With Quote
Old 07-29-2010, 03:38 PM   #9
swtwomyn
2003 KJ Liberty
It's working great...
Old 07-29-2010, 04:09 PM   #10
tjkj2002
2002 KJ Liberty
It won't for long.............
Pirate4x4.Com - Extreme Four Wheel Drive
There is alot more then just slapping a driveshaft in.
Old 07-31-2010, 10:46 AM   #11
goyle73
2007 KJ Liberty
just left the shop ordered the BDS lift kit with a set of General Grabber AT2s..245/75 16s... gonna do the install on everything next saturday if it all comes in on time .. now i just gotta decide weather i wanna put tow hooks on the front or go with a bull bar...thanks for the help everyone
Old 07-31-2010, 01:09 PM   #12
madrabbitt
Um, tow hooks.
Old 08-06-2010, 05:45 AM   #13
teamfast
2007 KJ Liberty
when you hit the beach air don your tires to a low psi, someone help me out here, 8 psi? Anyways that will help you immensely from sinking into the sand, air up again once you hit the streets.
teamfast is offline   Reply With Quote
Old 08-06-2010, 10:49 AM   #14
EvilashJEEP08
I usually go down to about 14psi with no issues at IBSP. You should be fine.
EvilashJEEP08 is offline   Reply With Quote
Old 08-06-2010, 12:31 PM   #15
WXman
You should have gotten 255/70-16s. For the beach, you want the widest tires you can fit...and the 255s would work and look better, not to mention in the Generals they are MUCH lighter and won't kill your fuel economy. Go back and tell them you want 255/70s.
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Daystar spacers - MB 72 wheels / 33" Falken Rocky Mountain ATS tires - ACE rock rails - Yukon 4.88s
WXman is online now   Reply With Quote
Glock Forum
