2007 KJ, A/C clutch doesn't engage - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 2007 KJ, A/C clutch doesn't engage
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineForever Wave Flags at JeepHutRubicon Express lift kits w/shocks are on sale!
Unread 06-04-2014, 01:23 PM   #1
Rob48
I am wondering if this may be a switch or relay problem. Is there anyway to test these before buying new ones?
Rob48 is offline   Reply With Quote Quick reply to this message
Unread 06-04-2014, 08:39 PM   #2
02blue
2002 KJ Liberty
If charge is low you can jumper the pressure switch and it should force the compressor to run. Don't want to do it for long but worth a try. Maybe it is low on refrigerant and needs to be evacuated and refilled.
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is online now   Reply With Quote Quick reply to this message
Unread 06-05-2014, 06:22 AM   #3
Billwill
2002 KJ Liberty
Swap the A/C Relay out with an identical one hopefully nearby and check all the fuses and put a voltmeter on the lead going to the clutch with reference to ground... Alas I do not have 2007 circuit diagrams
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline   Reply With Quote Quick reply to this message
