2007 Jeep Liberty Problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 2007 Jeep Liberty Problems
All Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 04-29-2015, 02:45 PM   #1
coltonhill
I have a 2007 Jeep Liberty Sport. When I accelerate quickly when it shifts gears it jerks really hard. It only does when I accelerate quickly.
Also, the air conditioner and heat does not blow on 1 or 2. It does blow on 3 and 4 as they normally would. 1 and 2 just don't blow anymore. They used to blow on all four. First 1 stopped then a little later 2 stopped.
coltonhill is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 05:33 PM   #2
95BadBoy
First post - Welcome to JF -
Your blower fan issue is caused by the failure of the resistor pack. Do a quick search on here - and you will find lots of info on how to fix that problem.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded
FS or FT (2) JK Rubi 17" Moab Rims - really nice shape
Need JK Rear Spare tire bracket for project
95BadBoy is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 05:40 PM   #3
draperjojo
1947 CJ2A
I would check the resistor block, which is probably behind the glove box. Do a search on the blower resistor, and I believe most people changing that out are going to a heavier duty version that chrysler makes.
draperjojo is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 06:54 PM   #4
02blue
2002 KJ Liberty
Here's some info on the blower resistor:
http://www.jeepkj.com/forum/f196/blower-resistor-57266/
It's behind the glovebox.
As for the hard shifting, has it just started doing this or has it always been this way? Might be normal but different from what you are accustomed to. Never hurts to check the fluid and have it serviced if it's been a while. I do a pan drop and partial fluid replacement every 30k.
"Hey, ya never know til you try." Kurt Russell-Big Trouble in Little China
02blue is offline   Reply With Quote Quick reply to this message
Unread 04-29-2015, 09:02 PM   #5
streetglideok
2005 KJ Liberty
How many miles are on it? How often has the fluid been changed in the transmission? Has it ever been used for towing, and has it ever been used on offroad trails at all, ie. going slow speeds for extended times on unimproved roads or trails, using 4wd, etc? I would suspect if the miles aren't really high, then you may just need the fluid changed, and possibly a conditioner put in with the new fluid. Will want to use the Chrysler approved ATF+4 fluid, and may need to have shift adaptations reset once the fluid is changed, or it may shift hard afterwards.
streetglideok is offline   Reply With Quote Quick reply to this message
Unread 05-04-2015, 07:47 AM   #6
JeepCares
FCA Customer Care
JeepCares's Avatar
Hey coltonhill,
I was unable to find a service bulletin related to the air conditioning concerns you have, but would like to look into your shifting concern. When experiencing the harsh shifting, what gear(s) is the vehicle in? Also are you up to date on your vehicle maintenance? You can find out what maintenance is recommended for the mileage mark your vehicle is currently at in your Owner Manual on pages 369-390. Here is a link the a digital version of your Owner Manual:
http://www.jeep.com/en/owners/manuals/
Let me know if you have any additional questions!
Andrea
Jeep Social Care Specialist
JeepCares is offline   Reply With Quote Quick reply to this message
