2006 liberty Tail Lights melting; Midas sketchy - JeepForum.com
post #1 of 15 Old 10-19-2010, 10:25 AM Thread Starter
acsguitar
So my wife has a Jeep Liberty 2006.
The other weekend we got pulled over. Both of her tail lights were out.
She got them swapped out at midas (she likes it there apparently) and the other day we noticed they were out again.
So she took it back and was wondering what was going on. Now they've told her that the bulp and socket/plastic is melted. They think the whole assembly needs to be replaced and want 400 bucks for it.
I'm wondering if this guys just popped in the wrong Wattage bulb and screwed everything up.
I'm wondering why they didn't notice the "Melted' problem when she first went in.
Apparently this is the issue via midas:
""loose plastic inside tail light lenses is contacting bulbs causing them to burn out. Tried to remove plastic from right rear lens and could not without destroying the assembly. Replacement of both lenses is necessary for bulbs to last.:"
Is that an easy fix
Anyways any ideas would be great.
Haven't posted here in ages! sold my wrangler recently to take the train
Colorado Jeep Club Member #55
2005 Wrangler X Rocky Mountain Edition
Jeep Noob and proud of it
[FONT="Fixedsys"]Need free computer help. I'm a nerd you can ask me.
acsguitar is offline
post #2 of 15 Old 10-19-2010, 11:28 AM
tjkj2002
2002 KJ Liberty
Yeah the wrong wattage bulbs could have been the cause but the 3-5 watt difference it would take a long time to cause any problems.
I would be keeping my foot of the brake pedal at long stop lights and drive throughs,put the vehicle in park and let off the brakes.Standing still with your foot on the pedal for long periods of time is the biggest culprit in melting housings,and yes replacing the whole housings is the only way to fix.
I never sit for any length of time(over 30 seconds) with my foot on the brake pedal and I still have the factory bulbs in my brake lights,that's 9 years.Saves on your brakes and trans fluid also.
tjkj2002 is offline
post #3 of 15 Old 10-19-2010, 11:58 AM Thread Starter
acsguitar
Thanks for the advice! I think the wife is just gonna pay them to do it. She makes the dough so I don't blame her. I'll tell her about that though. Interesting stuff
post #4 of 15 Old 10-19-2010, 01:42 PM
richd
2008 KK Liberty
This is most likely your problem,a design flaw from Chrysler:
Vehicle: Jeep Liberty (KJ) 2002-2005 (approx)
Concern: Right (or left) side tail/brake bulb keeps burning out. Customer has had bulb replaced numerous times.
Cause: A loose reflector piece inside the tailight lens is touching the bulb. Shake the tailight to check for rattle noise.
Resolution: Replace both tailight assemblies with revised parts to correct.
Details: Design flaw
richd is offline
post #5 of 15 Old 10-19-2010, 01:49 PM Thread Starter
acsguitar
hmm does that mean they'd cover it probably not but doesn't hurt to ask. Where did you get that from?
post #6 of 15 Old 10-19-2010, 02:04 PM
richd
2008 KK Liberty
No warranty on this unless your under warranty.I found this info on the net.
richd is offline
post #7 of 15 Old 10-19-2010, 11:06 PM
SabaII
Wouldn't hurt to try and get the dealer to pay for it. If it has happened before and you bring it to them, maybe see where richd got this info, and your not lightyears out of your warranty I would give it a shot.
SabaII is offline
post #8 of 15 Old 02-17-2012, 01:07 PM
cgkoon
This is absolutely true. I had the same issue with my 2006 liberty. After reading this thread, I removed my tail light assembly and the lens in the assembly was rattling around in it. You could even see where the light bulb had melted part of it. After looking online for a replacement and discovering that you would pay over $100 for one, I decided to fix it myself. I took a pair of tin snip shears and put the tip in the small hole for the socket and bulb and cut the lens into small enough pieces to pull it out. After doing this, I put it back on and it works perfectly. Thanks for the info on the problem. It saved me $100.
cgkoon is offline
post #9 of 15 Old 02-17-2012, 02:29 PM
tommudd
2004 KJ Liberty
100 bucks for one tail light
I have a pair here for sale 80 bucks
some people don't shop around do they
MUDD'S MOTORSPORTS
04 KJ JBA 4 IN COILOVER, 32s 4.10s
03 KJ JBA 2.5 T.C. LIFT, 31s 4.10s
tommudd is offline
post #10 of 15 Old 02-17-2012, 05:18 PM
95BadBoy
Ha ha, no - Tom your just faster on the draw in most for sale forums.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #11 of 15 Old 02-18-2012, 07:15 AM
Tpr430
2012 KK Liberty
Same problem here. Loose plastic/reflector piece inside was melting as it was contacting bulb. I put a couple drops of superglue (I think super) inside and glued the piece to the back wall or wherever sat better. Cant remember exactly, but haven't had a problem since.
Tpr430 is offline
post #12 of 15 Old 02-18-2012, 02:57 PM
BIG_J
2005 KJ Liberty
I did the super glue as well, then just left them flat for a wile. It does make the lens foggy, but the bulbs have been in there for 6months now with out issue.
The little JEEP that could.
BIG_J is offline
post #13 of 15 Old 03-31-2015, 12:34 PM
COOKIE2223
I was involved in a rear end collision in Oct 2014. I have been having this issue ever since the accident in my 2006 Liberty never before. So six months in the insurance co will not include this as part of the accident because of the online documented issue with the assemblies refractors dislodging. They cannot justify this as part of the accident claim even though I was rear ended by a Semi-Tractor trailer on the highway albeit at a low rate of speed there was over $4500.00 in damages to my Liberty and the lights did not appear to be damaged. My take on this is they obviously were damaged and there has been evidence of the whole brown residue due to bulbs burning since the accident. It will now cost me $290.00 to replace with aftermarket Tail Light assemblies that will not fail the same way the OEM assemblies do. Supposedly the After Market assemblies are guaranteed for life! WE SHALL SEE!! Bulbs have been replaced no less than 9 times since Oct. 2014.
COOKIE2223 is offline
post #14 of 15 Old 03-31-2015, 01:02 PM
remmons
There are some who have the design flaws, then there are those of us who beat our Jeeps to death off road and have no issues. I've replaced one bulb in the last 15 months and 33,000 miles, so I consider myself lucky.
Robert.
remmons is offline
post #15 of 15 Old 03-31-2015, 03:26 PM
tommudd
2004 KJ Liberty
I swapped out my 04 tail lights for 05 models in 2006, they had the original bulbs in them when I picked them up. Still working today with no issues
MUDD'S MOTORSPORTS
tommudd is offline
dead , liberty , tail lights
looking for liberty manual or tail wiring diagram 2002 liberty afgd1 KJ Liberty Forum 1 10-08-2010 05:30 PM
Looking to buy a 2006 Liberty CRD Limited LAjeep KJ Liberty Forum 19 11-08-2008 05:53 PM
2006 Liberty CRD Limited- Fog Lights bkr KJ Liberty Forum 0 11-22-2007 09:11 PM
Xenon lights for 2006 Liberty ?? Nick1150 KJ Liberty Forum 10 05-26-2006 12:56 PM
Liberty Tail Lights and Front Corners For Sale BugArt KJ Liberty Forum 1 12-06-2004 07:43 AM
