2006 liberty added weight distribution hitch and brake controller - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 2006 liberty added weight distribution hitch and brake controller
XT (ExtremeTerrain.com) has Barricade Off-Road Armor!ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wd
Unread Yesterday, 07:52 PM   #1
mjwhiting04
2006 KJ Liberty
2006 Liberty added weight distribution hitch and brake controller
We recently purchased a travel trailer 2800 lbs empty and found that we needed weight distribution to take some load off back tires.
We purchased a 600 lbs tongue weight max 6000 lbs max hitch setup. Easy to install but need to buy some large sockets.
We were able to take a drop in wheel well from 3-4 inches to 1 inch in the back. The ride is so much better.
We also added a brake controller and 7 way wiring.
Again easy to install besides the firewall wiring. That was a little challenging. Not easy to get to the port hole in the firewall had to feed pull wire from the inside.
For my jeep, it has a remote start and they tapped into the brake control switch wire so was easy to find white/ tan wire.
Loved how the panel under the steering column just pops off.
We feel safe now towing camper with sway bars and weight off the back wheels.
mjwhiting04 is offline   Reply With Quote Quick reply to this message
