2006 jeep Liberty blower motor resistor were is it at and how to get it out? - JeepForum.com
post #1 of 14 Old 10-06-2008, 05:39 PM Thread Starter
slickdevil72
2006 KJ Liberty
I have a 2006 liberty with the 3.7 V6 and my blower motor fan speed works on 2,3,4 speed's but not on number 1 the slow speed from what i've read its the resister that goes out most of the time and just the high speed works all my speed's work but not number 1 speed so its got to be the same thing.If i get a new resistor were is it at and how do u get it out to change it? is it by the blower motor itself? thanks for your time.
slickdevil72 is offline
post #2 of 14 Old 10-06-2008, 05:56 PM
hithere2ya
2006 KJ Liberty
Re; fan blower
I believe there was a recall on this, it is worth a call to the dealer even if you are beyond the mileage warranty period.
Alternately, there could be a fuse blown, they are located to the left of the steering wheel on the side panel facing the door.
Good luck!
hithere2ya is offline
post #3 of 14 Old 10-06-2008, 07:03 PM
Jakked
The resistor pack is pretty inexpensive and accessible through the glovebox.
I believe there are a couple of threads on this forum with instructions on how to change it; I'm sure you can find them with a quick search.
2004 Liberty Sport 3.7L A/T 4x4 Cmd-Trc
Former 4x4s:
1999 TJ 4.0L I-6 4x4 5-Sp *Mods*
1986 Trooper 2.3L I-4 4x4 5-sp
Jakked is offline
post #4 of 14 Old 10-22-2008, 06:50 AM
barbara061
Blower motor in a Jeep Liberty 2004 Sport
Where is the blower motor resistor item located in a 2004 Jeep Liberty ?
I am having the same problem and am going to try and replace it myself.
Thanks for any help,
Barbara061
barbara061 is offline
post #5 of 14 Old 10-22-2008, 09:01 AM
DryBones
Easy replacement, right behind the glove box. Drop the door on the glovebox and you can see it. I had the same problem with my 1 setting and bought the part from the dealer and replaced it in about 5 minutes.
DryBones is offline
post #6 of 14 Old 10-23-2008, 01:39 PM
Jeep03Lib
Blower motor
I have the same problem, however my #2 setting didn't work. Then all settings quit working. I replaced the blower fuse under the hood. Then my blower started working, however #2 was still dead. Then the blower quit working again. Then my battery went dead. The battery is five years old and I needed to replace it anyway. Purchased new battery. Now blower fan quits again all together. I haven't touched the blower resistor behind glove box. Thinking about giving it a try? Any help would be greatly appreciated.
Jeep03Lib is offline
post #7 of 14 Old 08-09-2009, 11:13 AM
rickxx
thanks for the great info. my resistor just went out. i'll check to see if it's covered under recall...if not, i'll pick up the part and replace myself.
rickxx is offline
post #8 of 14 Old 05-17-2010, 08:21 PM
KirkH58
I just fixed one in under 10 minutes and I am a painter by trade!
KirkH58 is offline
post #9 of 14 Old 05-17-2010, 09:17 PM
95BadBoy
For those that might read this thread on a search for a Jeep KJ resister pack,
Standard part# 5131719AA
Or you can use a much heavier duty resister pack from a Chysler Sebring for a few more bucks, and hopefully not ever have to do it again. Direct replacement.
Sebring part# 5174124AA
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #10 of 14 Old 07-06-2011, 11:44 AM
JLiberty79
2005 KJ Liberty
Barbara061
take a look at this link http://www.jeepkj.com/forum/showthread.php?t=35659
JLiberty79 is offline
post #11 of 14 Old 08-11-2011, 03:22 PM
msmmh
2006 KJ Liberty
Originally Posted by JLiberty79 View Post
Thanks for the link
msmmh is offline
post #12 of 14 Old 11-18-2012, 01:19 PM
nymom247365
2002 KK Liberty
My Jeep Liberty 2002 Limited is overheating and has plenty of anti-freeze and replaced the radiator fan because that is not working. The new one is not working either and all fuses work fine, any suggestions? Could it be the resistor and where can I find it and what does it look like?
nymom247365 is offline
post #13 of 14 Old 11-18-2012, 03:56 PM
95BadBoy
The resistor pack is a part of the interior blower fan equipment/control. If i'st going bad you lose one or more interior fan speeds.
Not what you are looking for. Other members will chime in I'm sure as to what points you need to start looking at.
Might be a good idea to start your own fresh thread, as this one is for a differant issue.
95BadBoy is offline
post #14 of 14 Old 11-26-2012, 08:54 PM
jerryrb
2007 KJ Liberty
avoiding resistor replacements
remember its a RESISTOR so its stopping the full 12 volts from getting to the fan so if you use 1 or 2 speed alot it will burn out cause the resistor gets HOT thats why they put it in the cold air box so it will get cooled off. i always use 4 or 5 and just regulate the temperture with the cold(blue) to hot(red) . my 02 still has the original resistor. just replaced a freinds 05 that he always uses 1 or 2 .
jerryrb is offline
New blower resistor and relay - NO FAN tutelo161 KJ Liberty Forum 6 06-21-2009 08:58 AM
Fan blower resistor part numbers Fourholer KJ Liberty Forum 2 04-12-2009 05:05 PM
Need help replacing blower motor resistor on KJ AVR2 KJ Liberty Forum 5 03-06-2008 01:04 PM
2002 blower resistor? blipszyc KJ Liberty Forum 3 10-01-2007 09:02 AM
2006 jeep liberty trouble Flipper2882 KJ Liberty Forum 4 11-10-2006 10:55 AM
