2006 jeep liberty - JeepForum.com
post #1 of 7 Old 04-01-2014, 11:34 AM Thread Starter
adamcomeens94
2006 KJ Liberty
2006 jeep liberty
wanting to put a rough country 3" with 265/75 general grabbers and wanting to make sure the tires will fit. any comments?
adamcomeens94 is offline
post #2 of 7 Old 04-01-2014, 12:29 PM
ewingtkepa
I'm not sure they would fit but they would look good if they do.
ewingtkepa is offline
post #3 of 7 Old 04-01-2014, 02:06 PM
tommudd
2004 KJ Liberty
Highly doubt it
You need 4 inches of lift to run 265-75-16s plus regear to 4.10s
Now that is a spacer style lift, KJs are known to sag over time ( example one rolled in here with 75,000 miles and was sitting over 1.5 inches lower than stock) Only way to lift one and do it right and have clearance is a full spring lift.
With that lift you may try and run 245-75-16s , they may fit depending on sag, but not 265-75s
Hope you have not already bought it
For what it costs you could have 4 springs paid for and then just need front and rear shocks
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #4 of 7 Old 04-03-2014, 03:34 PM Thread Starter
adamcomeens94
2006 KJ Liberty
will it rub harder and more likely in front of the wheel well? because i have a smittybilt tj bumper on the front with the stock front bumper completely gone. so im not worried about the front rubbing. and i know ill have to cut the unibody in the back of the wheel well.
post #5 of 7 Old 04-03-2014, 03:51 PM
tommudd
2004 KJ Liberty
DO NOT CUT the unibody in the rear part of the wheelwell, just bend it over with a large hammer after heating the liner to move it out of the way while you bend it over .
Again if you want to run 265-75-16s you have to have more lift I don't care what kind of bumper etc. There is not enough room in the wheelwells to run that sixe with one or two inches of lift. ( which is what you will have with sagged springs and a spacer lift)
Plus then you're still looking at regearing
With 245-75-16s you'll most likely get by with pounding over the pinch weld and using that lift , will be close but doable
MUDD'S MOTORSPORTS
tommudd is offline
post #6 of 7 Old 12-04-2014, 12:50 PM
ACM423
2016 JK Wrangler
I know I am a little late to the conversation but I have the 3" Rough Country lift on my '06 Liberty and am running 265/70/17 with no problem at all. 265/70 is what Rough Country says the 3" lift was designed for.
All that needs done is a little trimming of the Wheel Liner for the front wheels when turning.
ACM423 is offline
post #7 of 7 Old 12-04-2014, 12:54 PM
tommudd
2004 KJ Liberty
Measure middle of the wheel to bottom of the fender in front , just curious
MUDD'S MOTORSPORTS
tommudd is offline
