2005 Liberty p0038 code- Already replaced sensor - JeepForum.com
post #1 of 8 Old 05-14-2012, 07:29 AM Thread Starter
vXxo0oxXv
Hey guys,
I'm still getting a p0038 code after replacing the drivers side post cat o2 sensor. It's a Bosch sensor that I got from NAPA.
I guess the code means theres a high voltage on the heater element, so I'm thinking maybe there's an open in the harnass.
I have a meter, but I don't know where the other end of the connections for the heater element terminates. I dug through the FSV looking for pinouts, but I couldn't find them.
Any help is appreciated.
Thanks
vXxo0oxXv is offline
post #2 of 8 Old 05-14-2012, 07:40 AM
streetglideok
2005 KJ Liberty
Bosch aftermarket O2 sensors are known for being junk in the repair industry. NTK or OE is about the only reliable source for sensors. I would check for power to the O2 sensor heater on that side, among other things. If you look at the O2 sensor, usually there are two white wires, a grey, and a black. The two white wires are the power and ground for the heater. Figure out what color that connect to at the connector.
streetglideok is offline
post #3 of 8 Old 07-31-2014, 05:34 PM
vxxo0oxxv2
After 3 years, finally got this resolved
Turns out it most likely was that heater element in the Bosch sensor. Probably wasn't within the resistance specification. I replaced it again with the OEM sensor, and now the light is gone. I was ****ting bricks at first though. The code didn't clear, even after a battery disconnect/reconnect. After a few starts and letting it run, it went away though.
Hope this helps someone else.
vxxo0oxxv2 is offline
post #4 of 8 Old 07-31-2014, 05:40 PM
95BadBoy
Looks like that was a 2 year fix. Glad to hear things are up and running.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded - Sold 2015
95BadBoy is offline
post #5 of 8 Old 07-31-2014, 07:03 PM
tjkj2002
2002 KJ Liberty
And why you never use a bosch O2 sensor.
tjkj2002 is offline
post #6 of 8 Old 08-01-2014, 12:12 PM
remmons
I use to work for a factory over 11 years ago who had manufactured carburetor and emission parts. One of the parts that I had worked on were O2 sensors. There were only 4 or 5 manufacturers for O2 sensors. Each make would come in a box from its source that would work for a predetermined range of vehicles. There were only a small handful of variants to accommodate for the resistance levels. We would cut the leads to the specified length, according to the vehicle (or platform) that they were being made for on that production run. We would then gather up all of the necessary components, such as the weather grommets, terminals, and the connectors (per vehicle specs) and terminate the ends. It was only after that point that the O2 sensors have become vehicle (or platform) specific. What is funny is that Motorcraft is a Bosch unit. Bosch will work well for some makes, but not others.
Much like the spark plugs for our KJs, it's either the NGK (ZFRAR-11G) or the Autolite platinum (AP3944), which ever has been specified for YOUR KJ (as noted on the Vehicle Information Label located on your radiator support), no other make of spark plug will perform as well for the KJ application.
Robert.
remmons is offline
post #7 of 8 Old 08-01-2014, 07:19 PM
tjkj2002
2002 KJ Liberty
My Motorcraft O2's I bought for the Town Car are made by Denso,states right on the sensor and bought from the dealership and came out of a Motorcraft bag.
Oh and no platinum plug has ever been spec'd from the factory for any KJ or KK,or any 3.7 V6 that Chrysler made in the last 12 years.
tjkj2002 is offline
post #8 of 8 Old 08-05-2014, 09:26 AM
remmons
I'm trying to go through my memory as to where I have read this. It seems to me that I have read this elsewhere on our forum (and other forums) that this was true. If I have been misinformed I will correct this and give the correct information in the future.
Robert.
remmons is offline
2005 Liberty Sport CRD - EGR Error Code E401 gidkid KJ Liberty Forum 11 06-12-2012 12:30 PM
P0038 Code after going into weeds dac122 KJ Liberty Forum 3 07-19-2010 12:44 PM
P0038 Code? Need help Resolving.. SilverGT KJ Liberty Forum 11 09-30-2009 01:11 PM
Has anyone replaced a clutch on their liberty themselves? babes66 KJ Liberty Forum 3 07-24-2009 09:22 PM
Tire sensor (liberty 2005) maximebeauvais KJ Liberty Forum 5 11-27-2008 06:25 AM
