2005 Liberty Dash Removal - JeepForum.com
post #1 of 3 Old 07-09-2013, 08:51 PM Thread Starter
cecnnc
Does anyone have any pics, diagrams, videos of the dash removal process? Your help is GREATLY appreciated!!
cecnnc is offline
post #2 of 3 Old 07-10-2013, 01:03 AM
Billwill
2002 KJ Liberty
Remove the two "panic grab" handles on each side of the A pillars...you need to carefully pry out the rubber plugs and remove the two Torx screws in each side.
Now you can pry off the covers on each A pillar.
With these removed the long plastic strip that extends over the length of the dashboard...just below the windscreen...can carefully be pried upwards...it is held on by clips.
Now you will see how to remove the cluster assembly....one connector needs to be unplugged.
I do not know how much of the dashboard you need to remove, you can download the 2005 KJ Service Manual here
http://www.colorado4wheel.com/manuals/Jeep/KJ
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline
post #3 of 3 Old 07-10-2013, 06:06 AM Thread Starter
cecnnc
Thank you!!
BILLWILL...Thank you for the help and the manual downloads! This will make the job MUCH easier! Again thank you!
The reason I removing the dash is the AC condensation drain leaks into the passenger floor. I have cleaned it out and checked it with an inspection mirror. Nothing there. I can see all the way into the unit. But, it still leaks. I am assuming that the drain tube is cracked/broken. Any advice?
cecnnc is offline
