2005 Jeep Libety Low Beams Don't Work - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 2005 Jeep Libety Low Beams Don't Work
Engo LED Flush Mount Lights *PAIR* Flood or Spot 1,600 LumYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 10-16-2014, 08:07 PM   #1
Smokey4402
Low beams don't work at all. High beams are good. Already swapped out the low beam relay, fuses, and switch assembly on steering column. Any ideas?
Smokey4402 is offline   Reply With Quote Quick reply to this message
Unread 10-17-2014, 01:03 AM   #2
Billwill
2002 KJ Liberty
Have you checked the Bulbs are OK and the socket contacts are good and clean?
You sure you identified the Low Beam relay correctly...on the rear of the Junction Block.....small relay by itself on the lower rear of the block?
If you remove the Low Beam Relay and briefly jumper pins 30 and 87 together inside the relay socket then the this will test the wiring run from the Low Beam Relay all the way to the lamps....the low beam lamps should light unless the bulbs are blown or there is a bad contact somewhere.
If this does work only with this jumper in place then the BCM may have a problem as it controls the grounding of the Low Beam Relay coil.
2002 2.5 Export CRD Manual 5 speed.
Billwill is offline   Reply With Quote Quick reply to this message
Unread 10-22-2014, 04:42 PM   #3
richm20
2006 KJ Liberty
Check the "bulbs" although both going at the same time is rare.... You may have only noticed once the 2nd went out....
richm20 is offline   Reply With Quote Quick reply to this message
