2005 jeep liberty 4x4 issues 4wheel light. - JeepForum.com
post #1 of 17 Old 11-17-2013, 02:01 PM Thread Starter
satgdave
2005 KJ Liberty
ISSUE RESOLVED : replace transfer case switch.
About 2 month's ago I was in the hospital for 2 weeks and they notified me that there was gonna be work in the parking lot.. well I wasn't able to move it so they towed it up on a flatbed totally locked out from my car they dragged it onto the flatbed.. well something happened my 4x4 part time light is lit up in the console when its in 2 wheel drive.. I fixed it once by putting it in reverse and going back about 100' .. well today is a rainy day and I had to drive in my yard so I put it in 4x4.. well I turned it back to 2 wheel drive and the part time light is still lit up in the console.. any ideas? It says I'm in 4x4 when its in 2wheel.. I hope them dragging my car onto a flatbed didn't break anything..
satgdave is offline
post #2 of 17 Old 11-17-2013, 05:00 PM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
Glad you're back out of the hospital
Personally I would be giving the towing company - and the hospital maintenance supervisor - a piece of my mind. Yanking your your KJ up on a flatbed while in Park is just wrong.
As far as your dash indicator...The transfer case selector switch is a known problem and will give you false readings. Since the KJ gear selector is mechanical vs electronic there is no danger of your T-case being in the wrong slot (unless the cable breaks.) Here is a How-To on changing out the switch - the posts toward the end describe how to do it from the top through the console instead of from below.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #3 of 17 Old 11-18-2013, 06:47 AM Thread Starter
satgdave
2005 KJ Liberty
Thanks Bob.. ya they didn't even ask for permission to move it they just did..
Ic the part ur talking about it cost $95.. bummer. Wonder if I can change it without dropping the transfer case..
satgdave is offline
post #4 of 17 Old 11-18-2013, 07:05 AM
TwoBobsKJ
TwoBobsKJ's Avatar
2003 KJ Liberty
Thanks Bob.. ya they didn't even ask for permission to move it they just did.. Ic the part ur talking about it cost $95.. bummer. Wonder if I can change it without dropping the transfer case..
Oh yea, there's no need to drop the T-case. You can just come in from the top by removing the console. Some have come in from below to remove the switch and didn't drop the T-case. It's actually a fairly straightforward repair once you see where the switch is and figure out a way to get a wrench on it.
Keep shopping around for the switch - I've seen it for around $60 from various suppliers. Try RockAuto.com.
Bob
post #5 of 17 Old 11-18-2013, 08:09 AM Thread Starter
satgdave
2005 KJ Liberty
Thanks Bob!!
satgdave is offline
post #6 of 17 Old 11-18-2013, 08:29 AM Thread Starter
satgdave
2005 KJ Liberty
U know what that's a great idea to pull the console. Saves me from gettn covered in oil .... just hope I can pop off the console with out breaking any attachments.. hmm
$58 at rock auto thanks!
satgdave is offline
post #7 of 17 Old 11-18-2013, 09:16 AM Thread Starter
satgdave
2005 KJ Liberty
I ordered the transfer case switch.. will let u guys know if changing it fixes it!
satgdave is offline
post #8 of 17 Old 11-20-2013, 07:34 PM Thread Starter
satgdave
2005 KJ Liberty
I can't find it I took off the console and everything.. Help..
satgdave is offline
post #9 of 17 Old 11-20-2013, 08:05 PM Thread Starter
satgdave
2005 KJ Liberty
OK I didn't totally take out the central console BC of worrying of breaking any plastic clips.. help me. Thanks.
satgdave is offline
post #10 of 17 Old 11-20-2013, 09:36 PM Thread Starter
satgdave
2005 KJ Liberty
I need to remove the 4x4 leaver leather boot if I take a flathead to it will it come loose or am I just break it by taking it off BC it says it needs to come off. :/
satgdave is offline
post #11 of 17 Old 11-20-2013, 11:16 PM
John317
Unsnap the leather just below the handle, on mine I was able to just pull and work it loose. It just clips into place.
John317 is offline
post #12 of 17 Old 11-22-2013, 02:24 PM Thread Starter
satgdave
2005 KJ Liberty
OK will try.
satgdave is offline
post #13 of 17 Old 11-23-2013, 01:50 PM Thread Starter
satgdave
2005 KJ Liberty
OK just want to let u know I changed.. remove console the remove leather strap on 4x4 handle pry it off slowly and carefully after u get that off the place u need to be is right at the 4x4 switch un bolt the 4 or 5 nuts holding the switch onto the frame after u do that pull up and the transfer case switch is right there.. I don't think u can take it out with a wrench.. just no room to turn... so I bought a huge socket and turned it out
satgdave is offline
post #14 of 17 Old 11-23-2013, 01:50 PM Thread Starter
satgdave
2005 KJ Liberty
Also it fixes the issue by changing the transfer case switch..
satgdave is offline
post #15 of 17 Old 11-23-2013, 03:05 PM Thread Starter
satgdave
2005 KJ Liberty
Also I used a 3" extension with a 1 1/2" socket worked perfect fit right on the transfer switch..
satgdave is offline
