2004 KJ Rear End Thump - Page 2 - JeepForum.com
post #16 of 17 Old 02-01-2011, 05:29 PM
50rck
I have only had my KJ for a few months, so I haven't looked at this yet. Are the drive shafts balanced/keyed? Meaning they can only go on one way?
The reason I ask is this: I had a 1999 F250 Powerstroke that did something very similar, but only in cold winter months. It was a 6 spd manual, so it would do it each time I upshifted until after 4th gear. Turns out, it was the teeth and groves in the driveshaft where the slip yoke was. The cold weather would cause the metal to shrink a little, cause a very small amount of "slop". I replaced all universals, and the carrier bearing, but it still happened. Once the warmer spring and summer weather would arrive, I got no "thump". When the torque of the motor would kick in after an upshift, the teeth would "thump" against the groves. I actually packed a lot of thick grease in it, solved the problem for a while, too.
1991 YJ, rebuilt 4.0L in spring 2009 at 234,000 miles, no lift yet, slightly offset wheels, 235/75/15 tires for now, rag top, sold the hard top. Over 35,000 miles on the rebuild and counting.
2006 Jeep Liberty. Nothing special, all stock.
50rck is offline
post #17 of 17 Old 02-01-2011, 08:05 PM
waywardtravel
2006 KJ Liberty
Originally Posted by lilngineer View Post
What might be the problem in the rear diff?
BTW- I am mostly the mechanic on this one. The shop just took a free look at it for me on Saturday. (I also quickly took a look at the front drive shaft while on the lift. I asked him at that time if ge noticed anything else and all he commented on was the front brakes and a slight rear main leak.
I also asked about u-joints but he said they would be vibrating like crazy if they were the problem.
I would not rule out U-joints, Upper tri-link or lower control arm bushings, gear lash in the diff or anything for that matter.
Can you try to coast on a flat road and try to punch it. Then get up to the same speed in the same gear then Very lightly touch the gas (just enough to know when the engine is pushing the car a tiny bit) then punch it.
Then do the same thing leaving the corner into traffic kind of thing both ways.
Is it only one clunk Every time it does it. Can you feel it?
Usually a thump or thud description is more of a bushing or shock kind of thing (control arm or tri-link) and a bang or clank, loud crack could be more driveline, U-joints, ring and pinion lash etc,,,
It's really a crap shoot in my opinion right now given the current description.
Abuse the GO PEDAL
2006 gasser, Frankenlift, moab's, 245/75 KM's, JL Audio, Black windows.
1978 CJ5 304, T18, Dana20, Detroit locker, MSD, Edelbrock, etc,,,
waywardtravel is offline
kj , rear , thump
Adjusting the rear 2004 Liberty back door for no squeaks and rattles DARTICUS KJ Liberty Forum 0 07-20-2010 03:48 PM
How do you remove 2004 Liberty Rear Bumper? Tigey KJ Liberty Forum 3 10-31-2008 10:05 PM
2004 Libby Rear Window Problem KiteCrasher KJ Liberty Forum 0 04-15-2008 03:39 PM
Liberty 2004 rear window rattle Judysliberty KJ Liberty Forum 3 09-17-2007 08:10 AM
Rear Hatch opens on 2004 liberty jcbizzle KJ Liberty Forum 2 03-18-2004 11:28 AM
