2004 Jeep Liberty - Rust issues Cont - JeepForum.com
post #1 of 9 Old 02-21-2008, 11:43 AM Thread Starter
Anthony-NJ
Hey Everyone,
Just wanted to give you an update on my rust issue below the center tail light on the roof. If you recall rust was entering through the seal of the tail light and thus rusting from the inside out.
After a year an three quarters, and Contacting a lawyer as i couldn't deal with Jeep 17 in paramus's BS, they finally warrantee'd the rust. I haven't picked up the vehicle yet so i can't say if the rust was removed from the interior of the frame. or if the seal has been replaced. I will have to check on this when i get the vechicle back.
On a side note, they refused to do anything with my electrical system. As i've explained to all of you in the past, i reported the electrical problem to Jeep after 7 months after the rust was seen. What occurs is a few symptoms. While driving at night with the headlights on, My interior lights and exterior lights flash off/on multiple times, usually causing me to either get the finger from some guy in front or have to pull over cause i can't see.
Also my center console component lights (air condition, heat, etc) are semi lit, the left half is out and the right side is lit. There were times during this rust period that the lights would all light up and sometimes all go out. BUt right now its half and half.
I have a feeling this is all interrelated and due to the rust it cause electrial problems. Any suggestions on how to prove this. I will be talking to my lawyer as to our next steps, but wanted to know if anyone has any knowlege where any rust or water that entered through the rear tail light can short out the electric system.
Thx.
Anthony-NJ is offline
post #2 of 9 Old 02-21-2008, 08:37 PM
jeepjeepster
Sorry about the rust at the brake light. Ive seen some trying to start in that area too.
The A/C controls have lights in them that go bad. Im not sure if you can replace the bulbs but the entire control unit isnt that much $$.
The head lights going out are either the multi-function stalk or the BCM. The multifunction stalk has been known to cause problems like that. Check the fuses too. I had problems with my fog lights going on and off and I figured out the tabs where the fuse go in were getting a bad contact with the fuse causing the fuse to over heat. Bending the tabs back together took care of that.
Some rust around a brake light cannot effect the A/C controls or the headlights.
jeepjeepster is offline
post #3 of 9 Old 02-23-2008, 01:36 PM Thread Starter
Anthony-NJ
Interesting
I will doublecheck the Fuses, but i believe it might be BCM. But i've done some research and shorts can cause the BCM to go bad. If wires get wet it can cause shorts, and for all my lights in the entire vehicle to flash, i think its the BCM. DOn't know what that is or where it is but again, I can't seem to rule out that the Moisture that got in to the panels could of caused the shorts which in turn caused the BCM to go bad.
I'm going to bring it to a friend auto mechanic and have him look at the repairs that were made and just see if theres any way this could be true. If so then I just need a written statement from his company to give to my lawyer as evidence.
If not then awe well i'll have to bite the bullet one this one. It just seems to much of a coincidence to not be connected.
post #4 of 9 Old 10-26-2011, 11:22 AM
nhwalker
2006 KK Liberty
jeep rust issue
I have a 2006 Liberty with zero rust on the body--except that the roof started to rust (I noticed because it was in the center of the roof where it meets the windshield trim) I took it to be repaired and the shop discovered the roof and crossmembers under the roof were rusting from the inside. The shop told me they have had about 20 Libertys to repair with the same problem. Of course Chrysler refuses to assist ith the repair costs even though they are aware of the problem. A lemon law firm advises to get others with this problem to join in a class action lawsuit.
nhwalker is offline
post #5 of 9 Old 10-28-2011, 10:36 AM
captain78
2005 KJ Liberty
The problem with a class action is the only winners are the lawyers. Chrysler/Jeep may settle for lets say $2 million...first the lawyers get their 33% cut and the rest is split between those involved with the class action.
I once joined a class action and got a whopping $3.00. I spent more on postage mailing forms and info to the lawyers.
captain78 is offline
post #6 of 9 Old 07-07-2012, 12:32 PM
vibound
2005 KK Liberty
Another Liberty With Roof Leak
Last winter I noticed that our Liberty was dripping water inside under the area of the 3rd brake light. The vehicle was placed in the garage for the winter for storage as we had moved to the Virgin Islands. We just had it shipped to the islands and I noticed that the screws to the 3rd brake light were completely rusted and there is signs of rust under the paint around the light. I saw that you had a similar problem and that Jeep repaired it for you. Was there a recall on this issue or did they give you any documentation stating that it would be repaired at their cost. I'm look for direction as to who I should contact to take care of this issue
Thanks,
Rick
vibound is offline
post #7 of 9 Old 07-07-2012, 07:25 PM
tjkj2002
2002 KJ Liberty
Thanks,
Rick
Good luck,more so since it's no longer in the US.
tjkj2002 is offline
post #8 of 9 Old 07-08-2012, 08:52 AM
vibound
2005 KK Liberty
Usa
Hey, we're part of the USA. We're the UNITED STATES Virgin Islands.
vibound is offline
post #9 of 9 Old 05-22-2015, 10:24 PM
cobiaf
I realize that this was an old post that you made but are you still around? I too live in the U.S. Virgin Islands an have a 2006 Jeep Liberty Limited with only 46k miles on it that is rusting around the third brake light. Were you able to get anywhere with Jeep?
Thanks,
Cobia
cobiaf is offline
2004 Jeep Liberty Brake light problem Heart_USA KJ Liberty Forum 6 08-31-2011 10:51 AM
Jeep liberty 2004 Cluster going crazy Ioan_pavel KJ Liberty Forum 7 01-11-2010 10:00 PM
Heater fan not working in 2004 Jeep Liberty grossbeck KJ Liberty Forum 7 09-23-2009 04:09 PM
Stuck cd in 2004 Jeep Liberty barbara061 KJ Liberty Forum 2 02-12-2009 08:25 AM
2004 Jeep Liberty w/ bad intake valves jeepmama1 KJ Liberty Forum 11 08-06-2008 08:17 PM
