2003 Liberty rear brake shoes Emergency brake. - JeepForum.com
post #1 of 12 Old 07-15-2010, 08:45 PM Thread Starter
morhaven
Hi ,
I noticed my handbrake was not working well on my jeep.
my dealer advised me the Shoes are finished and springs are busted.
To replace 600$...because lots of time and labor..
This must be nuts. They are telling me they need to remove the Diff for this??
what are they talking about?
morhaven is offline
post #2 of 12 Old 07-15-2010, 09:35 PM
ahjjones
2005 KJ Liberty
I have the same problem! Can someone help?
ahjjones is offline
post #3 of 12 Old 07-16-2010, 07:46 AM
ryanee182
2004 KJ Liberty
I'm in the same boat. The last time I brought mine into a local 4x4 shop, and asked them to check the e-brake. He found the shoes were in pieces! They have to drain the diff and remove the axles in order to fix the parking brake. Then buy new fluid + friction modifier additive. He quoted me $350+ to fix it, and they only charge $50/hour labor. I opted to wait until I have some extra $ and will do it when my diff needs to be flushed/filled.
ryanee182 is offline
post #4 of 12 Old 07-16-2010, 08:10 AM
brucebotti
2005 KJ Liberty
Something sounds strange to me. Maybe the '05 is different, but I was able to get to the e-brake shoes by removing the rear disk (which has the e-brake drum built into it). There was no diff or diff fluid involved at all. Unfortunately, the e-brake doesn't work much better than before. It really looks like a Rube Goldberg setup.
Bruce
brucebotti is offline
post #5 of 12 Old 07-16-2010, 08:40 AM
ahjjones
2005 KJ Liberty
I just feel as if I don't have a parking e-brake at all. I mine as well just put it in Park and forget about using it because it rolls back either way.
ahjjones is offline
post #6 of 12 Old 07-19-2010, 08:56 AM
TSUKIKAGE
2003 KJ Liberty
You do not need to do that!. I just changed my parking brakes on my 03 libby - they were in pieces too. The assembly is inside of the rear rotor. Kind of a pain to get the springs back together, but not really that bad. take a picture before maybe.
TSUKIKAGE is offline
post #7 of 12 Old 07-19-2010, 07:52 PM Thread Starter
morhaven
coudl someone send me a howtu guide
does someone have a manual or onlne guide to replacing these rear parking brake shoes?
I also can;t believe the dealer wanting to remove the rear diff
morhaven is offline
post #8 of 12 Old 07-19-2010, 09:56 PM
tjkj2002
2002 KJ Liberty
Axle removal is the easiest and fastest way to replace the parking brakes.
tjkj2002 is offline
post #9 of 12 Old 07-20-2010, 06:06 AM
tommudd
2004 KJ Liberty
Yes much easier to get to them
Here's what you are working around/with
not on mine by the way, was doing this on a buddys
tommudd is offline
post #10 of 12 Old 10-26-2015, 04:35 PM
robertjblais
2006 KJ Liberty
Had to change complete assembly on both sides
If you need to change the backing plate or it had rusted out like mine, you will have to remove the axle shaft connect to lug bolts. I had to change both complete assemblies, I hope yours is not a 2006 or 2007 model because the assembly for each side is $250 - my dealer quoted $375 each. After you slide the axle off, you can just rip off old parts as the new assembly comes with everything installed. You remove four nuts and disconnect the abs and cable. Clean everything up, then reinstall the four nuts the abs and the cable, slide the axle shaft back in and reconnect. There is a forum I saw that explains how to this somewhere. Then go back to putting the rotors, pads and calipers back on. I changed the calipers and the rotors and pads also because it was removing one side because it had a bad caliper that I discovered how bad the backing plate was. So now I have new parking brake assemblies new rotors, pads and calipers on the both sides of the rear. You can see by the pictures that I have the axle shaft slide out, since I am doing both sides, makes things easier, I am waiting for new seals to come in the morning because I figure since I have it apart, I might as well do that now, since they are only $20 each and with my luck, after having all of this apart one of them would start leaking in a month or two. I also had a caliper which is what started this project so when done it will be an entire new brake system since I doing both calipers, rotors and pads. I cannot drive because of the medicine I am taking and fighting lung cancer so I am doing all this to pass my 2006 Jeep 4x4 6 cylinder Liberty Renegade on to my only son who is about to turn 23.
12039499_10207874349797123_7993268972860868929_n.jpg   12189759_10207874350157132_3968836920162646276_n.jpg   12187756_10207874350797148_5684339269164601495_n.jpg
Last edited by robertjblais; 10-26-2015 at 04:44 PM. Reason: correction and addition
robertjblais is offline
post #11 of 12 Old 10-26-2015, 06:37 PM
TwoBobsKJ
2003 KJ Liberty
Great work!
Your son will have a near-new Liberty. Best wishes in your cancer fight - prayers to you, brother.
Bob
2003 Renegade, Black
- 3.7L, 42RLE, 4.10's, ARB Bull Bar, Smittybilt XRC 9500lb Winch, 4X Guard Trans skid, Skid Row Engine skid, Factory T-case & Tank skids, Custom BoulderBars, JBA Front Coilovers, OME 948 rear springs, Bilstein rear shocks, JBA A-Arms, Moabs with Goodyear Duratracs 265/70-16
TwoBobsKJ is offline
post #12 of 12 Old 10-27-2015, 07:53 AM
Quickrunner
2004 KJ Liberty
Did it 2 days ago, no need to pull axel. There is a youTube vid. Super easy and parts were less than $30 at Autozone. The Frictuion liners had come off of the shoes and was making a clicking as wheel would rotate slow. Thought it was gonna be worse.
2004 Liberty Rocky Mountain edition, 2nd owner 112k miles
Quickrunner is offline
brakes , e-brake , emergency brake , brake shoes
2005 liberty Parking / Emergency Brake babes66 KJ Liberty Forum 15 03-07-2014 06:04 PM
Liberty Rear Brake Light Frequent Burnout Floridacatfan KJ Liberty Forum 11 05-23-2013 02:49 PM
Liberty KJ rear brake pad compatibility? sprintagogo KJ Liberty Forum 1 03-28-2009 07:58 PM
Liberty rear brake klunking after new pads and discs alane KJ Liberty Forum 21 02-09-2009 12:56 PM
Changing Rear Drum Brake Pads / Shoes AutoBot KJ Liberty Forum 5 11-11-2004 12:04 PM
