2003 KJ Limited Alarm Problem - JeepForum.com
post #1 of 2 Old 02-27-2007, 08:49 PM Thread Starter
All of a sudden my factory alarm on my 2003 Liberty limited has been going off when the Jeep is just parked. Does anyone have any idea what may be causing this? Thanks
Mr. Reeper
GRIM_REEPER is offline
post #2 of 2 Old 03-06-2007, 06:33 AM
I had the same problem with my 95ZJ. It turned out to be the sensor under the hood. Mine is located on the pasenger side. It was pitted which caused a poor contact. This is the way I found it ( and by the way- I don't know if the Liberty has the same diagnostic routine-). There is a routine you can kick off by turning the ignition key on and off a specific amount of times then opening and closing each door,liftgate and hood one at a time. You will hear one beep for everytime you open and close a door. I heard no beep when I opened the hood. That's how I knew the problem was the hood open/close switch.
Fern is offline
2003 KJ Idle and Stall Problem Gianmnm KJ Liberty Forum 8 02-12-2010 02:30 AM
2003 Limited Radio Crassshett KJ Liberty Forum 7 07-17-2009 12:46 PM
alarm problem? dicker KJ Liberty Forum 3 05-21-2009 04:51 PM
How to disable speed alarm on '05 Cherokee Limited? Dunebasher KJ Liberty Forum 7 09-06-2006 03:03 PM
XM into 2003 Limited Question webhead689 KJ Liberty Forum 2 01-12-2005 07:20 AM
