2003 jeep liberty maintenance - JeepForum.com
post #1 of 14 Old 07-02-2012, 07:54 PM Thread Starter
coolguy147
2003 KJ Liberty
hey guys! just joined the forum.
just got my first jeep looking to do some maintenance stuff on it and would like to get some advice
first off, i just changed the air filter with purolator pure one
looking to change the oil and filter
fuel filter
92k miles
what's the reliability? so far it's been good.
EDIT: also, are the fuel pumps on these SUVs generally loud? i noticed while driving that the fuel pump sometimes whines loudly
coolguy147 is offline
post #2 of 14 Old 07-02-2012, 09:13 PM
streetglideok
2005 KJ Liberty
Fuel pump really shouldn't be loud at all. In most cases, it should be almost silent.
streetglideok is offline
post #3 of 14 Old 07-02-2012, 09:18 PM
WillieWildcat
I'm not so sure your Jeep even has a fuel filter. A quick looks-see at Rock Auto confirms this. It blew my mind when I found out my '06 didn't have one. As for maintenance, you can never go wrong with Oil, Filter, Front and Rear Differential, Transfer Case, and Coolant Flush. I've never done a Transmission flush myself, I'm terrified of it. I'm a Ford guy originally and so I'm trained to let someone else handle that.
I'm going to change my spark plugs this week when I get a chance. But even that is weird; I don't have spark plug wires... Each plug has its own 'distributor'. Friggin' Jeeps. These guys at jeepforum have turned me on to Rock Auto for my parts needs (aside from my local AutoZone, anyway).
http://www.rockauto.com/
1999 Cherokee, 4.0L, 731k
2005 Wrangler, 4.0L, 70k WRECKED
1992 Cherokee, 4.0L, 174k SOLD
WillieWildcat is offline
post #4 of 14 Old 07-03-2012, 12:08 AM
cmartin2012
Changing your spark plugs is a good start, make sure you check the gap yourself-they will tell u they are pre-gapped, but each one was different when I did mine. The far rear passenger side can be a pain, just remove the coolant overflow mounted on the firewall.
It sounds intimidating-it's not. Because there are not spark plug wires you unbolt each coil pack and pull it out then u can get to the plug, its very easy just take your time and don't be in a hurry.
I would also seafoam your Libby. I do mine about 2 times a year. There are YouTube videos to watch and see how it's done. I just do the vaccum line-not the crankcase although you can.
Oil/filter
I did the transmission flush myself very easy, can be messy. Picked up the gasket and filter At napa took about an hour. Also on YouTube, sounds harder than it is-seriously.
Rotate tires, check brakes...pretty straight forward to change as well.
If u have more questions let us/me know and we can walk u through it.
Good luck, KJ's can be a lot of fun and pretty easy to maintain.
cmartin2012 is offline
post #5 of 14 Old 07-03-2012, 06:14 AM Thread Starter
coolguy147
2003 KJ Liberty
gracias guys! i'm a Ford guy myself too! own 98 grand marquis and man that thing is pretty easy to work on i'm used to the coil on plugs idea.
so this car seriously doesn't come with a fuel filter? should the strainer be replaced or something? no strainer? i was wondering about that too because i couldn't find one at rockauto either.
i seafoamed my grand marquis...shouldn't be too difficult with this thing. can i still use the brake booster line?
i have to replace the grill, grille insert, and driver's mirror glass. are these difficult to replace? they're broken in someway.
the fuel pump is generally silent but i noticed after dropping my friend off (in driveway) that it got considerably loud. never noticed it before.
5w-30 with motorcraft Fl-400s filter sound correct? 5 qts?
what kind of coolant does this Liberty take? anybody have a chart on what Chrysler used for coolants throughout the years?
BTW, only have 2wd....did any of these come with trac lok or anything? do i have to worry about a friction modifier?
EDIT: thanks for the help guys! i'm traditionally a Ford guy and but i really like the wrangler and dodge charger! :P
post #6 of 14 Old 07-03-2012, 07:05 AM
jeepkj617
2008 WK
the liberty uses HOAT coolant. Do NOT use green conventional or the one size fits all coolant. You can buy the HOAT coolant at either a jeep (mopar coolant) or ford dealer (ford gold coolant) - it should take a total of 1 gallon coolant and 1 water
"What do you mean it don't work? Just hit it with a bigger hammer!"
Thinking about buying a Cobra® 29-LTD 2-Way 40-Channel CB Radio. Anyone have install/antenna suggestions?
jeepkj617 is offline
post #7 of 14 Old 07-03-2012, 07:08 AM
streetglideok
2005 KJ Liberty
Chrysler uses HOAT coolant, its identical to Fords extended life gold coolant, just a different color. It is not the same, and not compatable with dexcool, which is what GM uses. Also as a note, dropping the trans pan and changing the filter is not a trans flush, and is not the same thing. I believe the earlier Libertys had an inline filter, but later models had a non-serviceable filter on the fuel pump module inside the tank. You can use seafoam, but it's mediocre at best at cleaning. Mopar, Motorcraft, BG, all make top end engine cleaners that make seafoam seem like water in comparison in cleaning. Only trick, you need an apparatus to spray it in the engine.
post #8 of 14 Old 07-03-2012, 03:17 PM Thread Starter
coolguy147
2003 KJ Liberty
can i use Ford's extended life gold coolant in my jeep?
i won't be doing anything with the trans just yet.
inline fuel filter? does my jeep count as an early jeep? where's the fuel filter?
post #9 of 14 Old 07-03-2012, 05:15 PM
tjkj2002
2002 KJ Liberty
Yes you can use Ford's Premium Gold coolant,you can use Zerex GO5 also.
You do have a inline filter,it sits right on top of the gas tank.
In the pic below the yellow box is the leak detection pump,the fuel filter for your KJ is to the right(drivers side) and above the leak detection pump.
tjkj2002 is offline
post #10 of 14 Old 07-03-2012, 07:50 PM Thread Starter
coolguy147
2003 KJ Liberty
good stuff, difficult to get to? how would a mechanic charge with the filter and all?
post #11 of 14 Old 07-03-2012, 09:01 PM
cmartin2012
In my 2003 the manual says 5w-20, but I do 5-30 now after 100,000 seems to work well for me...5qts is correct.
I seafoamed through the brake booster and worked well for me...at least on the top end.
When you asked about hearing the fuel pump are you talking about only before start up or while running? I can always hear mine load the line at start up if you turn the key one click before staring the engine...that has always been normal for me...kind a high pitch for a second.
Hope that helps.
post #12 of 14 Old 07-03-2012, 10:07 PM
tjkj2002
2002 KJ Liberty
Some early KJ's have a access panel under the rear carpet that you have to cut out to get to the filter,or drop the gas tank about 6" and access it that way(which I do).
5w-30 is the recommended oil till '06.No mention of 5w-20 in any KJ manual till '06.
tjkj2002 is offline
post #13 of 14 Old 07-03-2012, 10:08 PM Thread Starter
coolguy147
2003 KJ Liberty
Hope that helps.
the fuel pump whine upon start is normal for any fuel injected car lol?
i noticed at idle that it whined louder than normal lol.
post #14 of 14 Old 07-03-2012, 10:50 PM
tjkj2002
2002 KJ Liberty
Unless your hearing is in the dog range then if you can hear your pump something is wrong.2 biggest causes of loud fuel pumps is a partially plugged fuel filter or the pump is on it's way out.I've ran into both of those issues many times but running below 1/4 tank constantly is the biggest killer of fuel pumps,ask any GM owner when they run out of gas.Why Chryslers turn on the low fuel light when there is 3+ gallons left since the pump needs to be submerged in fuel to keep cool.
tjkj2002 is offline
2006 jeep liberty scheduled maintenance 99xjjoe KJ Liberty Forum 2 02-07-2011 05:16 PM
Just bought used 04 Jeep Liberty. What maintenance should I have done? tube517 KJ Liberty Forum 2 05-15-2010 09:57 AM
Jeep Liberty 60,000 Mile schedule maintenance, what's she love? :-) incucrash KJ Liberty Forum 2 01-23-2009 02:20 PM
My Liberty is 2005 year, is there any difference to do the maintenance in JEEP dealer pygmaro KJ Liberty Forum 3 09-16-2008 06:47 AM
Jeep Liberty 2003 + PCV valve bclarkuncc KJ Liberty Forum 3 05-19-2006 10:59 AM
