2003 jeep liberty 4 wheel drive problem - JeepForum.com
post #1 of 11 Old 01-05-2011, 11:37 AM Thread Starter
jpietruch
I have a 2003 jeep liberty that won't go into 4 wheel drive. I'm hearing a grinding noise coming from the front end. I don't think the front hubs are locking in properly. I have the factory service manual but can't find any reference to the front hub assembly as it refer to the 4 wheel drive system. I have worked on other 4 wheel drive problems. I would like to know where to start get the more information on the 4 wheel drive system or help as what I need to check.
Thanks Joe
jpietruch is offline
post #2 of 11 Old 02-01-2011, 11:48 AM
jimymc
2003 KJ Liberty
Liberty's don't have locking hubs. They are engaged at all times. It is difficult to determine what your problem is with so little information. Are you trying to shift into 4LO while you are rolling above 2-3mph? Which transfer case do you have?
jimymc is offline
post #3 of 11 Old 02-01-2011, 02:14 PM
WXman
He's right. The ONLY disconnect is inside the transfer case. Can you add more details about exactly what is going on?
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #4 of 11 Old 02-02-2011, 06:44 AM Thread Starter
jpietruch
I've never worked on jeeps before, all the other 4wd i worked on either had manual or auto locking hubs(no wonder jeeps get crappy gas mileage). Anyway the problem was solved with a front driveshaft change. the boot at the rear of the driveshaft(at the transfer case) had torn and the cv joint was bad. So I had to replace the whole driveshaft. Thanks for all your help.
Joe
post #5 of 11 Old 02-02-2011, 07:02 AM
tjkj2002
2002 KJ Liberty
Joe
You won't see any more mpg's with manual hubs on a KJ,maybe .5 more but that's stretching it.I ran for over a year with no front diff,CV axles,or driveshaft and never once got any better mpg's then when it all was in a spinning.
tjkj2002 is offline
post #6 of 11 Old 02-02-2011, 07:22 AM
WXman
Joe
Next time that happens, DON'T replace the entire driveshaft. You can buy the CV joint assy. for about $70 and fix it yourself. That'll save huge $$$$.
WXman is offline
post #7 of 11 Old 02-03-2011, 10:11 AM Thread Starter
jpietruch
the cv joint that was bad was the one on the rear end of the driveshaft (where it connects to the transfer case). that one is an integral part of the driveshaft, I guess it could be replaced with the correct equipment, but it won't be easy.
post #8 of 11 Old 02-03-2011, 12:43 PM
WXman
Actually it is easy. It's $70 and about 5 minutes of your time. All you need is snap ring pliers.
http://www.driveshaftparts.com/cv-jo.../prod_430.html
WXman is offline
post #9 of 11 Old 02-07-2011, 11:59 PM
Jomphe
Hey jpietruch,
My Liberty has been having the same problem. I've gotten underneath the car and seen where the boot has come off and everything.
I'm wondering how much it cost you to fix? because I'm not exactly sure what the CV Joint Assembly is but I'm pretty sure I need to replace the entire drive shaft...
Thanks,
Philippe
Jomphe is offline
post #10 of 11 Old 02-08-2011, 06:49 AM
tommudd
2004 KJ Liberty
Again
Listen to the above information
you do not have to replace the whole driveshaft assembly
very easy to do
contact ericautopart@aol.com
AutoPartsUnlimited
800-270-5224
he'll ship one out in no time
takes longer to remove it from the KJ than it does to swap heads
MUDD'S MOTORSPORTS
04 KJ JBA 4 INCH COILOVER LIFT
03 KJ JBA 2.5 TOTAL CONTROL LIFT
tommudd is offline
post #11 of 11 Old 02-08-2011, 07:42 AM Thread Starter
jpietruch
my bad you all are correct about the cv joint. After following the link, I saw the replacement joint. I assumed it was snap-ringed to the driveshaft but I didn't realize the cap could be removed so easily. I thought the end cap was pressed on and would be damaged when removed. In all the searching I did the only cv joint I found was for the front of the ds. I will have to keep that company link saved for future use.
Joe
Front Drive Shaft Question - Jeep Liberty 2003 Limited 4wd JeepLiberty2003 KJ Liberty Forum 29 03-24-2013 10:26 AM
A\C problem-2003 liberty rilson KJ Liberty Forum 2 06-04-2010 08:51 AM
Powertrain warranty problem 2003 Liberty jman1972 KJ Liberty Forum 16 02-12-2010 11:30 PM
WTB - 2003 Liberty Renegade Wheel ThaWstSide KJ Liberty Forum 0 11-09-2009 08:07 AM
2006 jeep liberty part time 4 wheel problem tjguy26 KJ Liberty Forum 1 11-01-2009 09:11 PM
