#1 | |
2003 3.7 in a 2002?
Hi Jeepsters! I have a 2002 Liberty Limited with a bad engine. I would like to know what range of engine model years would be easiest (besides the 2002) to install in my vehicle. I know of a local lowmileage 2003 engine and would prefer to not be changing mounts, computers, pulleys and the like. This Liberty was ran prolly 50K without an oil change and really got sludged up and ran low oil pressure until it chewed up the upper valve train on both heads. I pulled several golf ball sized chunks of oil chunks from under the valve covers!
Thanks! Bill in Fort Worth.
#2 |
Any 3.7L will work but for the easiest I think one from an '02-04 KJ would be your best bet.
1989 Jeep Comanche MJ: 2WD, 4.0L, BA-10, D30, D35, 4" IRO Front, SOA Rear, Winch Bumper, Trimmed Fenders/ Bed. Working on 2wd->4x4 Conversation. My Build: http://www.jeepforum.com/forum/f22/my-slow-build-89-jeep-mj-off-road-hunting-rig-pic-heavy-1268973/ |
#3 |
be carefull! some where aroung 2005 they changed reluctor wheels on the crank. if you get the wrong motor with a different reluctor wheel it will not start. mike
99xj, 4.0, aw4, nv 231 d-30, 8.25. dessert sand pearl. former rent a car from Enterprise. great shape! 06 kj 3.7l, 6speed manual, np241 command track 91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers |
#4 |
yeah thats why I only put the 02-04 bc those are all the same body style and everything
#5 |
Welp....after calling on an ad for a 2004 motor that the 2004 motor's flywheel will not bolt up to a 2002 torque convertor. I read that the 2002 is a 45RFE trans and the 2003-and on is a 45RLE. He mentioned being able to get one bolt on and all the rest of the bolts were not aligning at all. I wonder if the flexplate (flywheel) from the 2002 will bolt up to the 2003 or later engine. Jeeze...I miss the old days when a GM 350 motor would fit in just about anything....even my lawnmower
#6 |
oh sorry I didnt even think to mention the transmission, ya the 02's and some '03's have the 45RFE then the rest have the mini van transmission 42RLE
#7 |
When I replaced my 3.7 in my 02 I found that only the 02 and 03's where a even swap
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap 2002 Jeep Liberty Sport 4x4 3.7L Auto 1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
