2002 Liberty - wheel bearing - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 2002 Liberty - wheel bearing
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 07-23-2009, 08:15 PM   #1
jlupien502
My in-laws brought there Liberty in for an oil change at the dealer and asked them to look at a "thumping" noise coming from the passenger side front wheel.
Dealer determined it was the wheel bearing assembly and wanted $395 to replace it.
I know that they use a unit type bearing assembly. Can someone get me a service manual how-to ??
I'm pretty confident I can do this myself. I do all the repair work on my own vehicles. I just want to make sure I have everything together before I start because it's for the In-laws and you all know how that can go
jlupien502 is offline   Reply With Quote
Unread 07-24-2009, 05:06 AM   #2
95BadBoy
It might be an idea to look at the lower and upper ball joints too, ask the inlaws if thier 02 has had them replaced under the factory recall.
05 TJ RME 42RLE with some things
05 KJ CRD 545RFE, GDE Eco tune, Franky II, Al's 4.5 A-arms, JK Rubi Moabs, Silent Armors 245-70-17's, Spidertrax Adapters, Rola Basket, Fumoto Valve, Pinch welds pounded
FS or FT (2) JK Rubi 17" Moab Rims - really nice shape
Need JK Rear Spare tire bracket for project
95BadBoy is offline   Reply With Quote
Unread 07-24-2009, 08:19 AM   #3
jlupien502
I have her calling the dealership right now to check. Thanks
Unread 07-24-2009, 06:14 PM   #4
jlupien502
Alright. A check with the local Jeep dealer says the ball joint recall was taken care of in 2007, just before my in-laws bought it.
Back to the wheel bearing issue............. anyone ????
Unread 07-26-2009, 09:20 AM   #5
jlupien502
Anyone at least know what size the bolts are that hold in the bearing assembly ??? I know it's a e-torx , just not sure what size.
Unread 07-26-2009, 10:15 AM   #6
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Here's a Torx Chart if you've got some calipers. Point to point means the outside points not inside, ie - widest.
Bob
MK Skid Plate fasteners for sale posts 68 & 69
Also visit me at Photobucket
Gramps is offline   Reply With Quote
Unread 07-26-2009, 01:48 PM   #7
jeeplibby1
http://www.jeepforum.com/forum/f28/liberty-service-manuals-801654/ Is it 2 or 4 wheel drive? Mine was an inverted torx. I THINK it was a #4. I don't recall.
jeeplibby1 is offline   Reply With Quote
Unread 07-26-2009, 04:20 PM   #8
jlupien502
Originally Posted by jeeplibby1 View Post
http://www.jeepforum.com/forum/showthread.php?t=801654 Is it 2 or 4 wheel drive? Mine was an inverted torx. I THINK it was a #4. I don't recall.
I downloaded the service manual earlier. Wasn't much in there as far as bolt sizes but thanks.
I should be all set though. I just bought a 5pc set. It's definitely not a #4 though, looks to match up with the E-18.
Unread 11-14-2009, 11:10 AM   #9
Abby_Guts
2003 KJ Liberty
Just did my 2003 Bearing hub assembly. Bolts were E-14.
Abby_Guts is offline   Reply With Quote
Unread 08-23-2010, 07:03 PM   #10
Tavares
2002 KJ Liberty
My 02 liberty limited is make a noise when I drive seem's to me wheel bearing need to be replace ! My question now is can I replace this bearing without change the hub or hub has to be replace as well !
Anyone can help?
Tavares is offline   Reply With Quote
Unread 08-23-2010, 07:04 PM   #11
jlupien502
Anyone can help?
The bearing and hub is all 1 piece (sealed unit)
Unread 08-23-2010, 07:06 PM   #12
jlupien502
BTW... I never followed up on this.
It was a very straightforward job to do. Pretty basic and didnt take that much time..maybe an hour.
Unread 08-23-2010, 07:16 PM   #13
Tavares
2002 KJ Liberty
Thank you for this info!
Unread 08-23-2010, 07:17 PM   #14
Tavares
2002 KJ Liberty
I will check on line for price of hub.Thank you !
