2002 Liberty Taillight Issue - JeepForum.com
post #1 of 3 Old 11-11-2010, 08:23 AM Thread Starter
Liberty15143
2002 KJ Liberty
wondering if anyone has any ideas on a tailight issue. My left tailight will not work. The rurn signal works, the brake light works but tailight will not work. I have replace the bulb, replaced the socket. I was thinking about removing the right taillight assembly and connecting it to the left wiring just to rule out possible wiring, or tailight assembly. I want to belive its not wiring just for the fact that if the brake lamp works. Im know expert just to trying save some money
Liberty15143 is offline
post #2 of 3 Old 11-11-2010, 05:41 PM
richd
2008 KK Liberty
It still can be a wiring problem.Double check the wiring and make sure you dont have any shorting out,and make sure it has a good ground.Here is something I found for light problems on Libertys:
Vehicle: Jeep Liberty (KJ) 2002-2005 (approx)
Concern: Right (or left) side tail/brake bulb keeps burning out. Customer has had bulb replaced numerous times.
Cause: A loose reflector piece inside the tailight lens is touching the bulb. Shake the tailight to check for rattle noise.
Resolution: Replace both tailight assemblies with revised parts to correct.
Details: Design flaw
richd is offline
post #3 of 3 Old 12-22-2010, 04:13 PM
DAN C
Had this problem with my left tail light on my 03 Liberty. Remove the tailight (2 screws and pull) Check inside Where the wires connect to the harness. mine were all green inside and some of the pins were rotted away. I just cut out the connector and soldered the wires together and taped them up . Hope this may help
DAN O3 RED FREEDOM EDITION XOXO AIR INTAKE AIRAIDE THROTTLE BODY SPACER COBRA 75WXST CB ALL SKID PLATES & MOPAR DUAL OUTLET EXHAUST ALSO PATRIOT BLUE 02 LIBERTY LIMITED ALL OPTIONS EXCEPT SUNROOF
DAN C is offline
looking for liberty manual or tail wiring diagram 2002 liberty afgd1 KJ Liberty Forum 1 10-08-2010 05:30 PM
2002 Liberty wiper and airbag issue majose KJ Liberty Forum 1 04-21-2009 04:02 PM
2002 Jeep Liberty - Odd Issue CorradoGuy KJ Liberty Forum 0 07-08-2008 05:42 PM
2002 Liberty tommy2 KJ Liberty Forum 0 05-26-2007 03:30 PM
2002 liberty shawl KJ Liberty Forum 2 10-30-2005 08:48 PM
