2002 Liberty limited, Jangling sound mystery, Help?? - JeepForum.com
post #1 of 10 Old 05-20-2010, 04:03 PM Thread Starter
JeepJerry2112
2002 KJ Liberty
Hello. I have a 2002 liberty limited, 3.7l. After using 4wd this past winter (have no idea if 4wd has anything to do with it) the jeep began making a jingling sound from underneath, it only makes the sound when moving and gets louder and the jingling gets faster as I accelerate, it does not go away while moving, and is there everytime I drive. I have a little mechanical skill and checked thoughrowly for any loose parts, etc. underneath and found none. I brought the jeep for inspection an asked the shop to fix anything that was unsafe and would hinder my getting a sticker. They did put some brake pads on and took all of the wheels of and cleaned the brakes etc. and gave me a sticker. Still the same noise, so I went back and all of the mechanics had gone for the weekend....anyway it sounds like dragging a string with washers and spoons attached to the end. The noise seems to be coming from underneath the middle of the jeep somewhere.Any ideas, or similar experiences? Transfer case? Any help is appreciated. Thanks, Jerry
JeepJerry2112 is offline
post #2 of 10 Old 06-06-2010, 06:53 PM
jasondwalker
2002 KJ Liberty
Hi,
I had exactly the same symptoms with mine here in Australia and I can almost guarantee it is the front drive shaft. Mine failed at the cv on the transmission side. Replacement part here starts at $1300!!! Mine is currently spending a little time as a 2wd until I can source a new driveshaft from the US and get it shipped out here. I would recommend removing the driveshaft immediately in case it locks up...
Hope this has helped.
jasondwalker is offline
post #3 of 10 Old 06-12-2010, 12:34 PM
Scottm2010
I have the same problem! I will check it out to see if it is the front drive shaft.
Scottm2010 is offline
post #4 of 10 Old 06-13-2010, 10:51 AM
Budke
Remove your front driveshaft and drive around and see if it goes away. If it does, then there's your problem.
You can do a preliminary check and check the boot around the t-case end of the DS and if you notice any tears in it then you know that's your problem.
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
post #5 of 10 Old 06-17-2010, 02:23 PM
AVR2
Just to add, 99.9% it's the front driveshaft. Exact same thing happened on my 2005 KJ. From reading around various Jeep forums, it's a common problem with KJs (along with cracks in the radiator).
AVR2 is online now
post #6 of 10 Old 06-18-2010, 09:33 PM
BadKarma1701
noise
Great i just bought the thing. well i know what the noise is now. has anyone had this fixed and what did it cost you.
thanks
HONOR, TRUTH, LOYALTY, JUSTICE. DEEDS, NOT WORDS.
"I came into this world kicking, screaming, and covered in someone else's blood and I'm damned sure going out the same way!"
Sienna Jeep Owners Member #56
BadKarma1701 is offline
post #7 of 10 Old 06-29-2010, 02:15 PM
Scottm2010
Well, I just replaced my radiator because it had a crack in it... now to the next common issue. Haha. I would also like to know what it cost others here in the US to fix it. Is it something that you can still drive around on or should I get it fixed ASAP?
Thanks!
post #8 of 10 Old 06-29-2010, 02:16 PM
Scottm2010
Thanks!
post #9 of 10 Old 06-29-2010, 07:41 PM
curt7088
you can go to any auto parts store and pick up a refurbished drive shaft for about 370... or look online at CL or ebay... they have some up there for about 100...
curt7088 is offline
post #10 of 10 Old 07-02-2010, 09:47 AM
Scottm2010
Ok, sweet. Is there a specific thing that I should be looking for? Thank you very much!
Mystery Noise in my 2003 Liberty JFiske KJ Liberty Forum 9 03-08-2010 05:02 PM
Mopar Remote Start for 2002 Jeep Liberty Limited jaiasmit KJ Liberty Forum 1 01-16-2010 08:42 PM
Wheel and Tire, 2002 liberty limited twinjeep97 KJ Liberty Forum 2 12-28-2008 05:30 PM
PROBLEM W/ AC 2002 Liberty Limited AJ7 KJ Liberty Forum 6 05-05-2007 08:26 PM
2002 Liberty Power Locks Sound grabick_luca KJ Liberty Forum 5 01-29-2007 08:16 AM
