2002 Liberty Air Bag LIght on - JeepForum.com
post #1 of 17 Old 06-12-2009, 07:53 AM Thread Starter
seanskijeep
seanskijeep's Avatar
I have a 2002 Liberty and recently the air bag light has been coming on, More lately, i tried taking off the battery for over a 1/2 hour and that did not help. Is there anything I can do without bringing it to the shop?
2002 liberty sport
2002 grand cherokee
seanskijeep is offline
post #2 of 17 Old 06-13-2009, 01:10 PM
LibertyTC
2004 KJ Liberty
Air Bag control module
Best to take it to the shop/dealer.
The Air bag control module will store a fault code.
They can better diagnose fault.
LibertyTC is offline
post #3 of 17 Old 06-20-2009, 11:34 PM
Dvdjhooper
2002 KJ Liberty
Air Bag light problem
I suggest you might need to replace the clock spring. It is the package of electrical contacts underneath the steering wheel. The horn and cruise control buttons might have also failed. Do you hear a clicking or scratching sound from the column when the wheel is being turned?
Dvdjhooper is offline
post #4 of 17 Old 06-20-2009, 11:44 PM
jeeplibby1
Just made a new thread will alot of service manuals for 2002 KJ. Look at this and start on page 5. Although I think airbags are not a do it yourself project. They are dangerous. Hope it helps: http://www.scribd.com/doc/3287188/Je...cc-19-Steering
jeeplibby1 is offline
post #5 of 17 Old 06-21-2009, 03:40 AM
Billwill
2002 KJ Liberty
I had the same problem on my 2002 CRD. Removed the plastic covers around the steering wheel and the knee guard panel to get access to the connector that connects the spring connector to the wiring harness; it has about four wires as I recall. I initially tried cleaning/retensioning the contacts but eventualy I directly bypassed the connector and soldered the wires directly from the harness to the connector. Note that the connector on the airbag side has a small plate that shorts the connector pins out when the male/female plug is pulled apart; obviously to protect the airbag from picking up any stray pulse/static and going off unexpectedly. I believe one is supposed to have the airbags replaced after about 10 years so at that time I will get the dealers to do a proper fix.
Billwill is offline
post #6 of 17 Old 09-20-2010, 04:03 PM
hig116
Same problem after replacing radiator
I just replaced the radiator on my 02 Liberty and now the airbag light is on. It definitely wasn't on before I replaced it, so I'm wondering if I somehow caused this. Is there any wires or sensors in the area of the radiator that I may have damaged?
Thanks in advance for your help,
Keith Higginbotham
hig116 is offline
post #7 of 17 Old 11-07-2010, 01:49 PM
Xodius
hehe mine just popped on too. There are 2 sensors in the front, one on each side of the radiator. The first time I swapped my rad no problems. This time, I got a little over zealous and broke one, lol. Zip tied the hell out of it and seems to be working thus far. Pop your hood and on the drivers side look down past the large and small rad hoses. There you will see one of the evil little things. There is also one on the passenger side. Roughly same location.
Xodius is offline
post #8 of 17 Old 11-08-2010, 06:46 AM
hig
**Solved** Thanks
I swore I had replied to this with the my results, but I guess not. Sorry about that. I did find both of them and had done the same thing, broke the one on the drivers side. Actually, just broke the clip off the plug to hold the wires into the unit. So I too zipped tied to correct. Everything is fine now.
Thanks for your help,
Keith
hig is offline
post #9 of 17 Old 02-28-2011, 07:32 PM
oznext
2003 KJ Liberty
Guys, same thing happened to me today, just replaced the RAD and accidently i snaped out the sensor, i put it back but the light still on, something else i should do?....(maybe i broke the pins inside the male connector)
oznext is offline
post #10 of 17 Old 02-28-2011, 08:40 PM
Xodius
It happens lol. Mine pops on now and then just to say hi. My wife laughs at me cause when it comes on I say hiiiiii mr airbag.
Xodius is offline
post #11 of 17 Old 02-28-2011, 09:43 PM
oznext
2003 KJ Liberty
So you just have to plug it back and the light will go away? without disconecting the battery and stuff?
oznext is offline
post #12 of 17 Old 03-01-2011, 09:24 AM
SGTCornewell
2002 KJ Liberty
i pulled the passenger seat out to deal with a stuck seat belt latch. what would cause my light to stay on from that?
SGTCornewell is offline
post #13 of 17 Old 03-01-2011, 09:59 AM
tjkj2002
2002 KJ Liberty
Yes
tjkj2002 is offline
post #14 of 17 Old 03-02-2011, 10:55 PM
Xodius
I disconnect the bat but that is me. My father in law who used to work on them pulls the wires and resets them all the time with the batt still connected...I would never do that though. I zip tied mine and sometimes good sometimes not.
Xodius is offline
post #15 of 17 Old 03-03-2011, 08:47 AM
SGTCornewell
2002 KJ Liberty
tjkj2002, could you please give more than a one word answer? maybe, a solution that hopefuly doesn't involve a dealership?
2002 Liberty - Oil Light, Leaks, etc. muzicman82 KJ Liberty Forum 16 08-07-2010 11:00 PM
Battery Light on Liberty 2002. Help!!! LDaz KJ Liberty Forum 3 02-10-2010 06:42 AM
Electrical problems, dome light, radio in 2002 Liberty benny33 KJ Liberty Forum 3 08-12-2009 05:23 PM
Check Engine Light 2002 Liberty grabick_luca KJ Liberty Forum 11 06-16-2009 10:18 PM
2002 liberty runz KJ Liberty Forum 2 12-12-2008 04:18 PM
