2002 liberty - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 2002 liberty
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 10-30-2005, 11:35 AM   #1
shawl
2002 liberty
I'm looking at buying a 2002 liberty limited (52,000 mi) and have a question about the slight shimmy. It shimmies slightly when you accelerate and turn either right or left. I don't notice it when accelerating straight. Could this be due to a "trac-lok" rear axle (positraction)? I'm not sure if this vehicle is equiped with the "trac-lok" system. Is there an easy way to tell? thanks for any help.
shawl is offline   Reply With Quote
Unread 10-30-2005, 01:45 PM   #2
valvestem
Shimmy
There should be no shimmy under any circumstances. The rear axle has a paper band around the left end behind the wheel identifying either open or locked axle, very easy to see, if it is still in place.
valvestem is offline   Reply With Quote
Unread 10-30-2005, 08:48 PM   #3
LibertyV6
Doesn't posi-traction (limited slip diff) come standard on Limited? I know it is optional on Sport models.
[FONT=arial narrow]2004 Liberty 4x4. [B]All Black[/B] Columbia Edition
Sunroof, 5 spoke Graphite wheels
[U]ADDED[/U] MAGNAFLOW stainless muffler, Turbolator exhaust tip, K&N drop-in, ECLIPSE CD5000 8V HeadUnit, Infinity KAPPA speakers (all w/ Dynamat) run off RF 800a4 amp, One 12" [COLOR=DarkRed][B]KICKER[/B] [/COLOR] [COLOR=Blue]Solo-Baric[/COLOR] L7 subwoofer - run off RF 500a2 amp, 2 AURA under-seat bass shakers using alpine Flex2 amp, Front/ rear Mopar window flares, front slush mats, eurostyle antenna, Power Horn with Uniden PA Mic, 3" Smittybilt step rails[/FONT]
LibertyV6 is offline   Reply With Quote
