2002 Jeep Liberty overheating - JeepForum.com
post #1 of 11 Old 07-16-2010, 08:13 PM Thread Starter
feener
2002 KJ Liberty
Jeep dealer said i need radiator and thermostat, have not done yet. Another mechanic said to replace clutch fan, which we did. still over heating. IS it the radiator and thermostat? any other suggestions?
feener is offline
post #2 of 11 Old 07-17-2010, 01:47 AM
Budke
Is there coolant in the tank?
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
post #3 of 11 Old 07-18-2010, 05:53 PM
Jeepson33s
replace them...and while your at it, and if your wallet lets you, replace your water pump while all that stuff is out. I had the same problems with mine last year and all three were replaced and it works great now.
Jeepson33s is offline
post #4 of 11 Old 07-21-2010, 11:21 AM
aliens8443
2008 WK
mY ex-02 KJ had a cracked radiator and the coolant leaked very slowly, so it wasn't noticable until the radiator was almost bone-dry and the vehicle started overheating. had to get a new radiator only, and that was enough to fix the issue.
2004 Grand Cherokee Special Edition - Black, 4.0L I6
2010 Patriot - Silver, 2.4L I4, FD1
Ex - 2002 Liberty Limited - Blue, 3.7L V6
Ex - 2008 Grand Cherokee Limited - Black, 5.7L HEMI, QD2 (HEMI Club Member #50 Black WK Club Member #14)
aliens8443 is offline
post #5 of 11 Old 09-14-2010, 12:47 PM
pav245
2002 KJ Liberty
Had a minute radiator crack show up on my wife's 2002 KJ. It was high up on the plastic reservoir right behind the rubber air dam on the drivers side. New radiator was $175 at Autozone so I used JB Weld to fix the old one Was able to just drain the radiator and epoxy it without removing it. The repair worked great, but have never seen a radiator reservoir crack like that for no apparent reason such as stress or overheating.
pav245 is offline
post #6 of 11 Old 09-14-2010, 02:37 PM
tjkj2002
2002 KJ Liberty
I see about 2-3 cracked plastic tanks on radiators a week,it happens and there is no fix that will last very long besides replacement.
tjkj2002 is offline
post #7 of 11 Old 09-14-2010, 02:52 PM
pav245
2002 KJ Liberty
Thanks for the heads up. The hole was tiny but dissimiliar material expansion rates are a powerful force. I will keep an eye on the repair and see how long it holds up.
pav245 is offline
post #8 of 11 Old 11-19-2010, 05:48 PM
Rarguellez
hey pav245 my wife's jeep has a small crack in the same side same spot as u have mentioned. I have priced it at autozone here in Oklahoma and the cost is about 230.00.
Rarguellez is offline
post #9 of 11 Old 11-20-2010, 08:09 AM
HialeahAngler
it happened to mine about 2 yrs ago. I bought a new one and replaced it myself. I think the aftermarket one is better than the stock IMO.
HialeahAngler is offline
post #10 of 11 Old 11-20-2010, 05:59 PM
tjkj2002
2002 KJ Liberty
They all crack,and the OEM radiator is far better then any aftermarket one for a KJ and alot more $$$$.
tjkj2002 is offline
post #11 of 11 Old 11-21-2010, 03:58 PM
HialeahAngler
you're probably right. hence why I bought aftermarket. didn't pay much.
How to Bypass the A/C 2002 Jeep Liberty 3.7L 56_oval KJ Liberty Forum 1 10-04-2010 09:30 PM
Jeep YJ 15 x 7s on a 2002 Liberty cushtech KJ Liberty Forum 4 06-27-2008 06:06 AM
Jeep Liberty 2002 - Having problems getting key out Sertain KJ Liberty Forum 2 05-30-2008 03:32 PM
2002 Jeep Liberty, to buy or not to buy? Brian S KJ Liberty Forum 11 02-14-2006 04:06 PM
2002 Jeep Liberty?? aben8057 KJ Liberty Forum 5 09-16-2004 10:06 PM
