2002 jeep liberty five speed trans 6 cyl - JeepForum.com
post #1 of 4 Old 06-27-2016, 11:14 AM Thread Starter
pfontana
My five speed trans in my 6 cyl. Jeep liberty is noisy. I was told it's normal. I would like to know if I can use a thicker grade oil other than what the manufacture calls for. such as a 90 wt.gear oil.
pfontana is offline
post #2 of 4 Old 07-02-2016, 01:31 PM
KodiakKJ
2003 KJ Liberty
Im not sure about the thicker oil, but I know it has to meet the MS-9224 specification. I put Valvoline synchro mesh gear oil in mine and it it harder to shift into gear and doesn't like the cold very well. I don't know if it was ever changed before, either. Mine is on the loud side while in neutral with the clutch engaged, in first gear, and fifth gear.
Sent from my SAMSUNG-SM-G935A using Tapatalk
KodiakKJ is offline
post #3 of 4 Old 07-03-2016, 09:27 PM
streetglideok
2005 KJ Liberty
You probably shouldn't use gear oil. If you check the spec, they likely want a GL-4 spec fluid, not GL-5. They tend to be noisier, but you may want it checked for bearing noise.
streetglideok is offline
post #4 of 4 Old 12-13-2016, 12:43 AM
drowssap
Is the noise from the trans or the throw out bearing?
drowssap is offline
