2002 Jeep Liberty AC Compressor Seized Help Needed - JeepForum.com
post #1 of 31 Old 07-30-2008, 03:59 PM Thread Starter
BENGRFF
Hello,
I own a 2002 Liberty. The ac compressor seized and broke the belt.I live in northern Maine where ac is useless. What I'm wondering is if it is possible to install a remanufactured compressor and not hook up any ac hoses or any other connections to the compressor. I would like to use the pulley only. I have been unable to locate a bypass pulley for the Liberty. Will the pulley spin freely if it is not hooked to any connections. Any help that you could provide would be greatly appreciated. Thanks, Broke in Maine
BENGRFF is offline
post #2 of 31 Old 07-31-2008, 08:38 AM
COLORADO
i am facing the same problem. my compressor clutch bearing failed yeaterday. I will be checking to see if a belt is available for libertys without an air conditioner if this turns out to be to expensive to warrent repair.
COLORADO is offline
post #3 of 31 Old 07-31-2008, 08:46 AM Thread Starter
BENGRFF
Please let me know how it turns out for you. I tried at least a half a dozen belt lengths from napa and vip but wasn't able to bypass the ac compressor. Ben
BENGRFF is offline
post #4 of 31 Old 07-31-2008, 12:40 PM
COLORADO
After checking with jeep, They have a pulley which sits in place of the compressor and uses the same belt
The pulley costs about $75
COLORADO is offline
post #5 of 31 Old 07-31-2008, 01:28 PM
bssmith1220
I am having a similar quandary, I need to remove the compressor from a liberty, what is the best method to do that?
bssmith1220 is offline
post #6 of 31 Old 07-31-2008, 05:07 PM
Jeep dawg
2003 KJ Liberty
You guys removing the compressor and putting in the bypass insted?
I just replaced my compressore last week. It was an easy job. I bought a reman compressor for 299. mopar wants 800.00 for the compressor.
SCREW DAT!
reman is good enough for me.
the bypass should run you roughly, 90.00 or so
2003 KJ Sport JEEPZILLA Edition
FRANKENLIIFTED II W/HD coils
245/75/16x8 on Moab rims
Always new CV's and Drive Shafts
American Flag on spare tire mount
L.O.S.T. KJ# BL065211
Jeep dawg is offline
post #7 of 31 Old 08-07-2008, 02:51 PM
COLORADO
Jeep Dealer Quoted $450 To Replace Compressor. Junk Yard Wants $ 110 For A Used Compressor.
I Think I Will Go Used Since I Have 352,000 Miles On My 02, The Used Compressor Must Have Less Miles On It And I Will Be Selling Or Junking My 02 Eventually, I Just Bought An 08 Liberty. Ill Run The 02 Till It Dies
COLORADO is offline
post #8 of 31 Old 08-08-2008, 07:00 AM
JoBo
I'm not sure what brand of compressor we have but if it's a Sanden it may be possible to replace just the clutch or bearing bearing leaving the compressor on the jeep and not loosing freon It can be done this way on a VW Eurovan
Here's a link to their site.
http://www.rparts.com/Catalog/Major_...den/sanden.asp
JoBo
Columbus, Ohio USA
2006 KJ CRD Atlantic Blue Pearl Coat Limited
2000 Cherokee Classic with factory 16" wheels
JoBo is offline
post #9 of 31 Old 08-11-2008, 09:11 AM
COLORADO
Mine was a sanden but with the 350k miles I have on my liberty I figgured the compressor didn't have long to live.
I picked up a compressor at the junk yard, The liberty it came off had 12k miles on it. The whole job took less then an hour. I am debating weather or not to go thru the trouble of recharging it as winter is setting in
COLORADO is offline
post #10 of 31 Old 08-11-2008, 06:24 PM
skleinsmith
Might want to recharge it
Remember that if the defroster is on, the AC pump is also on. The "charge" is also the lubrication. Thus you should recharge it when you install it.
Shawn Kleinsmith
Igo, CA (Near Redding)
2004 Liberty (3.6 v6 gas) - Rocky Mountain Edit - Silver/charcoal
skleinsmith is offline
post #11 of 31 Old 08-12-2008, 05:36 AM Thread Starter
BENGRFF
Looking for a link to the bypass pulley
Hello,
Could somebody post a link to the ac bypass pulley for the Liberty. Thanks, Ben
BENGRFF is offline
post #12 of 31 Old 08-12-2008, 08:54 AM
COLORADO
I have the clutch power disconnected at the moment
COLORADO is offline
post #13 of 31 Old 12-06-2008, 10:43 AM
artstarzz
2003 KJ Liberty
hello
i am getting ready to replace the ac on our 2003 liberty . if i want the warranty that comes with the ac it says on the box i have replace a filer and a hose . has anyone replaced an ac on a 2003 liberty .
artstarzz is offline
post #14 of 31 Old 12-06-2008, 02:12 PM
dcxman
2006 KJ Liberty
If you guys use a bypass pulley, let us know how it turns out with the defroster on. I'm wondering if it will be raining inside.
06 Jeep Liberty crd- 245/70/16 tires, fumoto valve
03 Neon
96 Ram 1500, 5.2,
99 Harley Sportster
88 Ford 350 diesel dump truck
02 Northwing Maverick Legend weight shift trike
dcxman is offline
post #15 of 31 Old 12-07-2008, 09:14 PM
COLORADO
I bought a compressor from the junk yard for $100 for my 02 liberty. took about 20 minutes to install
COLORADO is offline
2002 Liberty A/C Compressor Clutch Strorg KJ Liberty Forum 12 06-11-2013 03:59 PM
2002 Liberty AC compressor...Help?!?! jojer1 KJ Liberty Forum 3 05-19-2009 11:20 PM
Jeep YJ 15 x 7s on a 2002 Liberty cushtech KJ Liberty Forum 4 06-27-2008 06:06 AM
2002 Jeep Liberty, to buy or not to buy? Brian S KJ Liberty Forum 11 02-14-2006 04:06 PM
2002 Jeep Liberty?? aben8057 KJ Liberty Forum 5 09-16-2004 10:06 PM
