2002 3.6 4x4 TUNE UP assistance - JeepForum.com
Go Back JeepForum.com > Models > Jeep Liberty Forums > KJ Liberty Forum > 2002 3.6 4x4 TUNE UP assistance
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Alloy usa heavy duty ball joint kitsENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 10-12-2014, 04:30 PM   #1
rosco219
So I have heard a bit about the headers on these things going bad any feedback on that topic I am sure will make for good convo.
2) Spark plugs which kind is best / most economical, difficult to change?
3) Tranny fluid and transfer case fluid ... where are the drain and fill plugs? Which kind of fluid is best?
4) grease spots for the front end? or in general?
5) do these things have coil packs? or fuel rail coils, distributor?
6) Any thing else I should go over on this jeep maintenance wise?
7) My sunroof open light just blinks on and off... and the shade that you slide to block the sunroofs sun from coming in is gone... Is this replacable?
8) anything i should check with the 4x4 ??
rosco219 is offline   Reply With Quote Quick reply to this message
Unread 10-12-2014, 05:08 PM   #2
tommudd
2004 KJ Liberty
First you have a 3.7 not a 3.6 , next only use NGK or Champion copper core plugs, not platinums etc
Automatic or manual transmission?? ATF4 if automatic , and have to drop the pan, transfer case has fill and drain on the back side of it
None if nothing has been replaced with greaseable zerks, have to check LBJs etc to see
Individual coil pack above each plug help on with 10 mm nut
front and rear diffs both should be done as well
Do you have an owners manual , check the glove box, small slot at the very top if you haven't found one
04 Liberty, Kilimanjaro Edition, Rock Lizard RockRails/Roof Rack/Front-Rear bumper,32 inch Goodyear Duratracs,Moabs,4.10s/ 4.25 inch JBA Coilover lift /other goodies
tommudd is offline   Reply With Quote Quick reply to this message
Unread 10-13-2014, 07:38 PM   #3
rosco219
Ok thanks tommudd.
I just swapped out the plugs with Autolite coppers. There were bosch platinums in there and they looked pretty white but not to bad.
Now onto the differential fluid changes. I changed one a while back on a 2000 xj 2wd . Similar? Which fluid?
Any advice on the sunroof problem? My open light just blinks and the controls seem to be out of sync.
